Old 04-27-2015, 03:49 PM   #31
You could always add an auxiliary gauge, if you can tee into the plumbing.
Old 05-03-2015, 02:10 PM   #32
midlifekrisiz   midlifekrisiz is offline
went out for a test ride yesterday to find that my wet clutch is poo poo and that my rad (I think) is leaking from the pressure of the new water pump....new wet clutch and one way bearing ordered but going to try a rad additive to see if I can seal the rad for now till I can save up for new rad and relocation kit
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div>
Old 05-03-2015, 02:56 PM   #33
When you get a new rad, it will be a good time for new hoses and a thermostat. Everything will be top notch and reliable then.
Old 05-06-2015, 08:05 AM   #34
turns out it wasn't the rad but the rad cap that failed .... new one on order
also my new wet clutch and one way bearing were ordered and showed up yesterday afternoon.....2 days from ordering off ebay
Old 05-06-2015, 11:15 AM   #35
That's quick! When does surgery begin?
Old 05-06-2015, 12:52 PM   #36
That's good service. I love eBay.
Old 05-06-2015, 08:08 PM   #37
today !!!! still have lots to clean wait till you se what the shive that has the rollers in it looks like....gona blow your mind
Old 05-07-2015, 01:13 AM   #38
I'll bet they're flat.
Old 09-28-2016, 08:37 PM   #39
update
sorry I haven't been on here posting much ...been busy with life and such.
I have added the following since last post;
new thermostat, new water pump, cleaned and re-greased the rollers, changed 2 axles, new brakes, rad relocate kit, snorkels and a rear seat.
I will upload pics tomorrow.
Old 09-29-2016, 11:05 AM   #40
Got pics?
Old 09-29-2016, 01:07 PM   #41
Got pics?
oh of course I do lol
just need to find the time to upload them......working a stupid shift from 1030 am to 830 pm -_-
will get them in here soon
Old 09-30-2016, 11:31 AM   #42
so here is what the rollers looked like when i first took it all apart......wayyyyy too much grease in there
take the plate out and this is what i found
not alot of room to run the snorkels in here
ended up cutting out allot of plastic and have to relocate my winch control but it is what it is
all installed rad re-locate and snorkels
had to trim one of the tabs off the rad cap so that i can turn it -_-
thats it for now ...i am sure i have some more pics around here somewhere.
Old 09-30-2016, 03:57 PM   #43
katoranger's Avatar
Does Yamaha recommend the rollers be greased? I know that on my Honda Elite they were suppose to be dry. The ones in the buggy are dry too.
Old 09-30-2016, 04:40 PM   #44
yes but very very little .....there is a set of rollers you can get for them that do not require grease but in stock set up you apply a very thing skim of grease .......definetly not what the PO had done here (guy was an idiot)
there was so much grease and dirt in there that the rollers couldn't even move.
Old 10-03-2016, 11:37 AM   #45
I bet it felt like a new quad after cleaning all that grease out.
