Old 05-07-2015, 11:03 AM   #3376
Originally Posted by jezzrite View Post
What is the name of this connector?
This is the connector that comes attached to the cigarette socket.
2) And this?
This one is attached to the USB port.
I suspect that forum member Cheesy knows the answer. I recommend that you send him a PM.
Old 05-07-2015, 11:11 AM   #3377
Originally Posted by SpudRider View Post
The shock valve of the RX3 is definitely a high pressure valve. It is not a schrader valve such as is employed in motorcycle inner tubes. I was in error to describe this valve as a schrader valve.
That hadn't occurred to me, but it makes perfect sense that a Schrader would only be capable of 100psi or so. A quick search has not revealed the actual tolerance of a typical Schrader, but I have found several warnings against using a Schrader in a high-pressure application, like a shock.
Old 05-07-2015, 11:12 AM   #3378
Originally Posted by pete View Post
But there is another issue I noticed in the pic....
the clutch cable retaining tag on the motors clutch
arm has never been bent down to stop the clutch cable
droping out of the arm.....
Bend it down.... it's the tag sticking out beside the word "UP"
on the cable seat....
Nice job, eagle eyes!
Old 05-07-2015, 12:46 PM   #3379
G19Tony   G19Tony is offline
G19Tony's Avatar
I'm happy to pass that tip on. I learned it from a smart gentleman on another forum.
It took a lot of washers, but I got the spring on.
Honda CB300R ABS
Old 05-07-2015, 12:54 PM   #3380
woodlandsprite   woodlandsprite is offline
woodlandsprite's Avatar
what, no photos? glad you got the spring installed
Old 05-07-2015, 02:59 PM   #3381
Good for you, Tony.
Old 05-07-2015, 04:16 PM   #3382
katflap   katflap is offline
katflap's Avatar
Stumbled across this Dyno test result for the Rx3 EFI engine
Thought it might be of interest to some.
Old 05-07-2015, 04:39 PM   #3383
jimjr21   jimjr21 is offline
25.6hp @ 8994 rpm
This is a brake dyno of some type. Easy to tell by the rpm time trace. Engine is at maximum rpm then is pulled down to lower rpm over 6 seconds. These types of dyno's are hard on engines.
Currently In the garage in various states of running (or not) order
2015 Rx-3 super speedy blue
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
1952 Ariel Square four
Old 05-07-2015, 06:40 PM   #3384
Thought it might be of interest to some. ...
Indeed, it is of interest to me. Thanks for sharing the data, Kat.
Old 05-07-2015, 07:01 PM   #3385
I just got back from a 60-mile ride to test the shock preload adjustment I performed on my RX3. The ride contained interstate, secondary, and tertiary paved roads, including city streets. I also rode dirt and gravel roads. Tightening the spring preload adjustment on the shock absorber a mere three turns resulted in a very significant improvement in shock performance.
The shock absorber is still reacting a little too soft for my taste, so I am going to tighten the spring preload another three turns.
Old 05-07-2015, 08:56 PM   #3386
G19Tony's Avatar
New battery and power outlets
The WPS Li-On battery arrived today. It went into the bike with no issues. It weighs 2.4lbs, but it sure feels lighter than that. The bike fired right up.
I installed the instrument panel power outlets the other day. It was a fairly straightforward process. I removed the windshield for better access. The wings came off easily, and the outlets went back in just as easy. I was a little stumped as to where the power box goes. (I can't remember the proper nomenclature!) A quick call to Steve answered the question. It goes behind the right rear panel. Removing the plate under the pillion seat is the easiest way to access the connector. I will plug things in later tonight and see how they work. The windscreen was a little fiddly to put back on.
Honda CB300R ABS
Old 05-08-2015, 12:06 AM   #3387
The battery looks great, as do the power outlets.
I think it is easier to install the windshield if you install the lowest bolts first. If necessary, install the windshield loosely before you install the headlight. Then it will be much easier to tighten the lowest bolts on the windshield.
Old 05-08-2015, 12:33 AM   #3388
AZRider   AZRider is offline
I wasn't able to get my fingers behind the windshield to hold the nut, so I used a pair of needle nose pliers to hold the nut and then got the bolt started finger tight.
George
2016 CanAm Spyder F3-L
Old 05-08-2015, 12:52 AM   #3389
G19Tony's Avatar
What happened to my oil?
When I got the new battery in, I started the engine for about 30 seconds. The oil in the sight glass went away, as expected. It's been 4 hours and nothing has drained back to the case. Did I do something wrong when I did the oil change? No leaks noted. I'll check again in the morning.
Honda CB300R ABS
Old 05-08-2015, 01:00 AM   #3390
Thanks for posting the good tip.
I made the mistake of installing the lowest bolts last, instead of first. I couldn't use needle nose pliers, or even a pair of tweezers to hold the nuts. Therefore, I had to resort to using a telescoping magnet to hold the nuts to get them started.
http://www.harborfreight.com/18-inch...net-37187.html
Install the lowest bolts of the windshield first.
