Experimental TEFLON Crankcase Seal / Nc250/Zs177mm
Zs177mm/Nc250 moto block crankcase has not have metal or paper or.. a seal, just i see on surface very thin probably slikon / or high temp plastic seal trace .
Many forums,and my friends sad replacement crankcase seal methode(if not find, fabricated original seal) slicon applicated , offcourse me too try that , but crankcase in surfaces very thin , and i fear if much more applicated that slicone=very badly engine damaged/blocked oil pump/bearings/oil channels/filters/gears, and i just tested 2x time slicone. Very thin applicete slicone+sponge , my moto master friend sad, use a sponge and very very thiner app slicon , and vibrated+impacted sponge slicon seal is form better thin than a paper , i make that and test again screws mounted waiting dry = crankcase in , badly situtaion (out case not important ofcrs.) failed. İnside of crankcase better leak. Slicon seal not for me, i understand , but i need a seal material, perfect temperature , oil strenght , what is material what is... think think ... happy end , i find that TEFLON band... ![]() Used a 19mm Teflon band , making double layer , and roll thread , crankcase in applied , Teflon thread and aluminium surfaces incompatible , just need very low profile applied a glue(glue type is dry soft glue, not Japan type, or steel type.) This methode is experimental think.. , my moto need refesh paint+eectrical replacement , proobably 2 weeks or more time need completed, after i returned here and writied here , i hope this methode is ok. Never try this methode , just wait my test results. Last edited by Co2; 12-18-2015 at 12:35 PM. |
I have never seen teflon tape used in this capacity in over 30 years of engine rebuilding.
Personally I use Wurth brand Flange Sealant Green. It was developed for Rolls Royce aircraft engines to seal machined surfaces. I most commonly see engines with Yamabond or Hondabond sealing them. Again products designed to properly seal an internal combustion engine coming in contact with oil, fuel, coolant, etc. I will be looking to see your results. I hope they are positive. I worry that the tape rolled will have too much thickness and distort the machined tolerances and alignment.
Currently In the garage in various states of running (or not) order 2015 Rx-3 super speedy blue 2003 BMW F650GS 2001 H-D V-Rod 1999 Ducati 750SS 1997 Yamaha Riva 1995 KTM 250 1970 Honda CB350 1952 Ariel Square four |
I have seen gaskets for the ZS177MM (NC250) engine sold at Taobao. However, I don't remember seeing a gasket for mating the crankcase halves.
![]() https://item.taobao.com/item.htm?spm...cket=12#detail
#4 | |
Can you recommend any of the Permatex gasket makers? http://www.permatex.com/products-2/p.../gasket-makers
#5 | |
Photos first try's , latest version better visual and reasuring ,smooth. İhope to, that methode succes... if failed 4. time demontaged moto block ![]() |
#6 | |
![]() Gaskets on picture, little camshaft tensioner , cylinder up+down , clutch decorative case, waterpump ,stator case , and bigger right crankcase side gasket's. Sorry worng word of topic "Seal" , " Gasket bettter. |
The chinese stuff: http://www.huitian.net.cn/product_intro.asp?id=141
I've used Three Bond and Loctite 518 with good results.
I really like the Permatex Ultra Black RTV. I use it for a variety of purposes. Which of the Permatex products do you think would work best to seal the two crankcase halves?
I did a little research, and a lot of people swear by Permatex Ultra Grey.
![]() http://forums.g2ic.com/showthread.ph...ndabond-vs-RTV http://www.k20a.org/forum/showthread.php?t=94798 http://www.permatex.com/products-2/p...t-maker-detail ![]()
Hmm , my that project started i fear in the crankcase owerflow all semifiluid gasket materials , and blocked any actioned in motor parts fear , that all semifuid materials finded easy , but crankcase two surface closed very sharp/thick surfaces , if any semifuid used 100% owerflow in motor.
Probably first montage from moto factory using a robotic gasket aplication, and perfect montaged, first demontaged crankcase surfaces very very thinner gasket how i can description idk probably gasket material thickness 0.01 -0 .03 mm maximum all effort so that , leaked semifluids. İ hope , that semi elastic material, tolarated that problem i hope. Last edited by Co2; 10-08-2015 at 10:43 AM. |
#12 | |
As others pointed out the gray is a good all around choice.
My favorite is Loctite 518 or whatever Permatex calls it nowadays. I used it for years on motorcycle crankcases, Rotax aircraft engines, washing machine transmissions, and everything else that did not need the spacing of a paper gasket.
#14 | |
I've had similar results with Three Bond. I would not use silicone.
#15 | |
![]() http://www.loctite.co.uk/loctite-408...=8802626633729 ![]()
