Old 10-08-2015, 09:36 PM   #4291
Co2   Co2 is offline
Originally Posted by ElectricCircus View Post
Hi Co2.
The manual states that the RPM signal for the tachometer is generated by the CDI module, Y/B (yellow/black?) wire.
My suggestion: remove the seat and look there for any loose connector, specially those at the CDI module. Will help doing that with the engine running at idle, looking at the RPM indicator while moving the cables: if the RPM needle jumps or becomes alive again, you'll got the point of faulty connection.
Thank you , now i check my model mauel, that lcd display has not have RPM section :(
And manual too diagram not marked any data for tachometer , probably Cdi box unit to not have , :(
But i need a simple RPM clock how i can make that easy way idk , just i think maybe same moto block type same methode measured but my mistake...
Old 10-09-2015, 05:45 AM   #4292
ElectricCircus   ElectricCircus is offline
ElectricCircus's Avatar
Ok, I understand now.
If you need to check the RPM sometimes at the workshop there are unexpensive digital multimeters suited for this.
Can't figure an "easy way" for adding a permanent tachometer: the least difficult method would be to add a "tach-only" gauge; the simplest of these units senses the RPM using a wire coiled a couple of times over the spark plug cable.
______________
- ex Honda MB100 (1981)
- ex Honda Nighthawk 250 (1991)
- ex Honda Storm 125 (2009)
- ex Corven Triax 250 Touring (2016) (Zongshen RX3 carb)
Benelli TRK 502 (2018)
Old 10-09-2015, 07:06 AM   #4293
Co2   Co2 is offline
Thank you , yes that pictured device i need, very simple just applicte spark cable(i think)
Multimeter ? electronic measurement device or?
if that multimeter mean Hertz measured if possible that solved my problem because i need RPM meter just need gas thortle marked and RPM relationship marked on gas thortle , first 3000 kilometer RPM limit run. (how i can do? )
This methode is correct?
Old 10-09-2015, 07:27 AM   #4294
Co2:
We are off-topic, so I'll send you a Private Message to avoid messing this thread. Ok?
______________
Old 10-09-2015, 10:46 AM   #4295
katflap   katflap is offline
katflap's Avatar
Volt Meter
I while back I fitted one of these voltage meters
http://www.ebay.co.uk/itm/Waterproof...item46399f6876
Cheap but quite accurate.
Here's some AGM battery info i have gathered together
Charge state (voltage at battery terminals)
100% 12.8v - 13.2v
75% 12.5v
50% 12v
25% 11.5v
(mine is about 12.7v with the ignition on.)
Voltage when starting engine should be no lower than 9.5v
( mine is 10.4v)
Voltage with engine running 13.5v - 14.8v
Old 10-09-2015, 02:30 PM   #4296
As always, thanks for posting the good information, Kat. If you have time, please post a photograph showing where you mounted the voltage meter.
Old 10-09-2015, 02:36 PM   #4297
MattyBoy1976   MattyBoy1976 is offline
MattyBoy1976's Avatar
Canada!
Posted on October 9, 2015
Folks, the RX3 is now approved for sale in Canada!
Details are available in our most recent press release, which you can read here:
http://www.prlog.org/12500774-csc-rx...in-canada.html
For our Canadian friends, if you want to know more, please give us a call at 909 445 0900 or contact us at info@cscmotorcycles.com.
Posted in CSC Motorcycles | Comments Off
Here ya go, Weldangrind...
2009 TW200 (first bike ever, sold it!);2015 RX3 Cyclone in blue (first "big kid" bike ) with 13T front sprocket, 19" front wheel, center stand, heated grips, LED aux lights, CSC skid plate
Old 10-09-2015, 02:41 PM   #4298
Thanks! Reading it now...
Old 10-09-2015, 02:48 PM   #4299
Hmm...
Wondering if the price is $3495.00 Canadian, and if that includes shipping as well. I'm very close (within 35 blocks) to the U.S. border, so that could be an option as well.
Old 10-09-2015, 03:06 PM   #4300
It certainly was a lengthy, and probably costly, endeavor, to get the RX3 certified in Canada. I'm glad to see the bike is finally available for sale, north of the 49th parallel.
http://californiascooterco.com/blog/?p=18412
Old 10-09-2015, 03:08 PM   #4301
Hmm...
If you want the definitive answer, place a telephone call, or send an email to CSC.
Old 10-10-2015, 12:43 PM   #4302
katflap's Avatar
Had to place it here in the shade as glare from the sun made it difficult to see. The voltmeter in this spot is still visible when riding Name:  v meter.jpg
Chasing a pesky buzz/rattle I had me speedo apart .
The idiot lights (SMD style LEDs) are hidden beneath the black plastic square. Though you can't see it in the photo the black square has transparent portions in the shape of the indications shown.
Old 10-10-2015, 12:49 PM   #4303
katflap's Avatar
Some bloke on one of the Chinese forums has fitted an hydraulic clutch
Name:  h clutch.jpg
Old 10-10-2015, 01:05 PM   #4304
Longboarder1968   Longboarder1968 is offline
Thumbs Up Repair manual
This just arrived in Colombia, think it will be well received. Anyone have a link to English repair manual? RSD!
Old 10-10-2015, 02:09 PM   #4305
Welcome; we are glad you joined us.
You can find links to manuals, and many informative threads by perusing the RX3 Tech Sticky, which is permanently pinned to the top of this forum.
http://www.chinariders.net/showthread.php?t=14228
