05-10-2017, 08:24 PM | #1 |
Oil cooler install
My oil cooler finally came in today. It took me about an hour to install. After I installed the cooler I added oil with the provided syringe. I cranked it up to prime the oil lines and checked the oil level and added a little more oil. I took a ride down the road and came back and check the oil again. A check valve is not needed if you connect the line out from the engine to the bottom of the cooler. I let it set for an hour and the oil didn't drain back to the engine. I'll have to shorten the line with the filter when I get a chance.
Addition info: I used a piece of 1" angle iron using the two motor mount bolts at the bottom . After I mounted I realized I could flip the cooler mounting bracket and will set the cooler further back and the oil lines will be behind the angle iron. I'll take care of that and post pictures when I get to it.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 06-02-2017 at 11:08 AM. Reason: added more information |
05-10-2017, 08:36 PM | #2 |
Looks good! Is that one from mj? I'll get one eventually.
On a side note, if you tweak that wire retainer for your front brake line, you can get it to go inside of both of those ridges on that rubber insulator. It takes some judicious bending and squeezing with pliers. My OCD made me do it! |
05-10-2017, 08:42 PM | #3 | |
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-11-2017 at 07:50 AM. |
05-10-2017, 09:17 PM | #4 |
I agree...looks great. Well done indeed
05-10-2017, 11:17 PM | #5 | |
Yup, To the point it's cheaper 1 at a time with shipping than in bulk as China post small items are pretty cheap to ship. I got 6 of the valve cover coolers in with the stacked plate coolers and shipping alone was $129 usd. My wholesale price with shipping in bulk is more than you paid. Still waiting on seeing if they can come up with an UNCRIMPED end on one hose but haven't heard back. On your routing, Not sure it make a lot of difference on a bike but on cars, Trucks, Heavy equipment and hydraulic systems the hot (out) line always goes to the top as heat rises and if it went into the bottom the cooler/radiator efficiency is compromised. Just food for thought.......... |
05-11-2017, 01:46 AM | #6 | |
05-11-2017, 07:45 AM | #7 | |
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-11-2017 at 09:48 AM. |
05-11-2017, 10:05 AM | #8 |
Post some pictures of your install. If I remember right you had installed a check valve on yours. It will work that way just have to make sure that the cooler is filled completely with oil so that air will not get trapped in the cooler. But I know you knew that already. It was nice that they supplied a syringe with the kit to do that.
05-11-2017, 10:41 AM | #9 | |
Just send the units out with a check valve that way when installing the check valve the length could be adjusted then.
05-11-2017, 03:07 PM | #10 |
I like the mounting plate solution, very clean and it looks almost factory.
One of these is definitely in my plans. I honestly would love to be able to buy the kit without the lines. Just the cooler, filter, check valve, and block for the filter screen port. I have about 20ft of 3/8ths 316L Stainless hard line coil and a mountain of -6 AN fittings I bought for another project I would love to plumb this up with. |
05-11-2017, 03:41 PM | #11 | |
05-11-2017, 09:37 PM | #12 |
The last few samples i got the cooler Banjo fitting is bigger than the adapter fitting for the motor.....
05-12-2017, 06:11 AM | #13 |
Maybe my just woke up brain is confused. Trying to say you have a kit or two without lines? If so... How YOU doin!
05-12-2017, 09:05 AM | #14 | |
05-12-2017, 09:57 AM | #15 |
Great. I don't think I ever seen a pictures of your bike. BTW I check the oil level last night and the oil didn't drain back to the block so I guess a check valve is not needed. I'm going to flip the mounting bracket this afternoon when I get home. that push the cooler back about 2".
