Old 06-19-2017, 07:11 AM   #1
Rideon   Rideon is offline
Rideon's Avatar
Head Scratching Making the right
Well I've done some of the mods to hawk led lights in the cluster and tail/brake light.
I switched out the 15 tooth front sprocket to the 17 tooth sprocket ,the Mikuni carb is on its way Its in VAVA'U , TONGA in the middle of the south pacific and tonight I am going to rip the cat out of the exhaust .
Oh and already have the jet kit for the Mikuni
Old 06-19-2017, 12:23 PM   #2
pcspecialist   pcspecialist is offline
Needs: https://www.facebook.com/photo.php?f...0&l=303a2b8100
Old 06-20-2017, 10:28 PM   #3
Sport Rider's Avatar
can't beat that color!
Old 06-21-2017, 02:47 PM   #4
RustyShackleford15   RustyShackleford15 is offline
I got the same carb on the way from Tonga! Im pissed that Amazon didn't disclose the amount of time it would take to arrive.
Is there a way to remove the cat without having to cut and reweld the pipe? Im having problems finding someone that will Tig weld for cheap since its alum.
Old 06-21-2017, 04:15 PM   #5
The stock exhaust on the hawk is steel not aluminum.
Old 06-21-2017, 05:00 PM   #6
JeremyC   JeremyC is offline
Yep, not aluminum, and find a welding shop that has a heli-arc outfit. Nothing else will weld this low carbon crap (not proper welds, anyway).
Old 06-21-2017, 05:06 PM   #7
When did you order your carb? I did on the 12th and its still showing only the origin scan and still on the island.
Old 06-24-2017, 10:01 AM   #8
Rideon's Avatar
I ordered mine on 15th and as of yesterday it cleared the LA. CA. facility
Old 06-24-2017, 10:53 AM   #9
Rideon's Avatar
Originally Posted by pcspecialist View Post
Thanks for the ideas, I already made my own windshield out of a scrap piece of Plexiglas .
I held off on pulling the cat out till the carb gets here.
Old 06-24-2017, 10:37 PM   #10
dpl096   dpl096 is offline
dpl096's Avatar
Well done
― Thomas Jefferson
Old 07-05-2017, 10:36 AM   #11
Rideon's Avatar
I made me a motorcycle jack out of a old scissors jack that had been sitting in the garage for years it was the only thing left that was any good after a 15yr old kid stole my ranger and made it two feet shorter lol.
Old 07-05-2017, 10:46 AM   #12
Good idea. I repurposed a hydraulic floor jack and did something similar with angle iron.
Old 07-08-2017, 10:48 AM   #13
Rideon's Avatar
I have the VM26 Mikuni carburetor on the hawk now 110 main jet middle needle position
1 1/2 on the mixture screw what a difference no more riding around half choked .
It starts and idles on full choke for 30 seconds then to half choke for about a minute
then your off and riding .
I still have the exhaust pop when decelerating but I think that's because the cat is still in the header pipe and is probably igniting the un-burned fuel.
Also changed out the rear knobby for a Shinko 700 4.60-18 it doesn't feel like i'm riding down railroad tracks anymore much smoother on the street .
Old 07-15-2017, 12:49 PM   #14
Rideon's Avatar
I finely cut into the catalytic converter and pulled it out it was a bit of a pain but not too bad
I cut it open with a body grinder with a cut off wheel on it which made a rather wide cut and that made welding it back up a little ruff but i got it sealed backup, if I was to do it again and i'm not I would have made the side cuts with a hack saw thinner cut I'm not going to show the welds pretty ugly lol .
I used a hole saw on a drill press to cut through material that made it pretty ez to remove the cat.
I also cut the cap off the spark arrester while I was at it.
The bike seems to run smoother and has a little more power.
Old 07-15-2017, 01:06 PM   #15
Ariel Red Hunter's Avatar
If you change the pilot jet to a 30, I think it will reduce the popping in the exhaust, as well as improving the performance up to 1/2 throttle...ARH
