Old 06-07-2018, 10:10 AM   #31
Does the Hawk use an 8 or 10mm peg pin?
Old 06-07-2018, 10:12 AM   #32
I didn't measure. If it's 8mm then i'll drill out to a 10mm.
Old 06-07-2018, 10:15 AM   #33
My interest is more along the lines of, I don't want to order 8mm and it is 10 lol
Old 06-07-2018, 10:26 AM   #34
What, you don't have a hole shrinker.? Just drill out the foot peg for a 10mm pin if needed.
Old 06-07-2018, 10:27 AM   #35
No, I lost my metric hole shrinker. It was in the same tool bag as my metric channel locks.
Old 06-07-2018, 12:15 PM   #36
No, you sold it. It's called a welder.
Old 06-07-2018, 03:04 PM   #37
That is what my MIG welder is for, including my spool gun for aluminum.
I sold my TIG setup
Old 06-07-2018, 05:55 PM   #38
Darkrider   Darkrider is offline
There was someone on here at one point who made adapters to use BMX bike pedals as pegs.
Past bikes:
'10 Gio X33
'85 Honda VF750F Interceptor
'80 Honda XL185S
'76 Yamaha DT250C dual sport
Baja Wilderness Trail 250
'07 Honda Shadow 750 Areo Trike
'01 Harley Davidson Softail Deuce
Polaris Magnum 425 4x4
Originally Posted by andyj812 View Post
You can't pin this one on me, my wife is still mad at me. I don't need your wife mad at me too. LOL
Disclaimer: The above post by 2LZ is in no way the view of this site, other members or Bruce's llama. It is the opinion of 2LZ and 2LZ alone. ;-)
Old 06-07-2018, 06:21 PM   #39
Cravin01   Cravin01 is offline
Cravin01's Avatar
That first post was extremely informative, really gets me thinking about what I'd like to do. could you imagine being one of the first owners of a China Bike WITHOUT THIS FORUM!!!!!!!!!
OH! I would really like to hear what you think of that gel battery when you get a chance to try it out if you could please.
Visit me on YouTube at "Project Next"!
https://www.youtube.com/channel/UC6KTCi2GVbfRDv-2XCqHhsg?view_as=subscriber
2017 Bashan Storm
Keihen PZ30 Pumper Carb,115 main jet,35 pilot jet, gutted factory exhaust, Sambo Digital Speedometer,LED blinkers, H4 headlight,D.I.D X-ring chain 428,17/42 sprockets,UNI cone filter.
Old 06-07-2018, 06:45 PM   #40
I would get by ok without the forum, but it would be a lot more leg work on my part. This stuff comes second nature to me thanks to owning seceral old bikes with little aftermarket support lol.
I will definitely report back on the battery and other parts of interest. It should work just fine though.
Old 06-08-2018, 01:05 AM   #41
ChipToothy   ChipToothy is offline
I really would like longer (wider outward) pegs, if anything. My wide feet struggle lol
My left partially rides the peg and partially rides the kickstand. I’ve corrected countless times already but it keeps ending up there. The right side I have to point outward to avoid riding the brake and peg together but I constantly find it has creeped and riding both. I also strongly feel the pegs should be inches more forward to keep my weight off the bottom of the gas tank and more on the sit bones. Would probably be better for driving as well to not be scooted against the tank every 5 seconds.
I don’t think these bikes are built for people over 6 feet tall but with 8 inch long arms. Like a TRex build.
Old 06-08-2018, 10:24 AM   #42
I set up bikes so that I can ride with my boot over the brake pedal, without activating the brake. I'm more comfortable knowing that I don't need the extra reaction time of moving my foot laterally before pressing the brake. I'll do whatever I need to in order to adjust the brake pedal that way.
It sounds like you could benefit from a couple of changes. Perhaps reshaping the seat foam could stop you from pitching forward, which results in the feet pointing outwards. Maybe a shorter shock would also allow you to level out a bit. Just my $0.02
Old 06-08-2018, 10:26 AM   #43
I sold my TIG setup
Everyone knows that only a TIG can shrink metric holes. You're going to need a conversion chart with a MIG.
Old 06-08-2018, 10:29 AM   #44
I remember that. I thought about it, but decided that Pivot Pegz might be a better idea, since they spring back to neutral when your foot is removed. I think I'll just stick with my generic wide foot pegs.
Old 06-08-2018, 07:26 PM   #45
Dan, the pin is 8mm.
