Valve cover leaking oil
so it looks like my valve cover is leaking oil. not sure if it is the valve cover gasket or the screw that is on the very top towards the carb. it looks to have some kind of washer and oil is up in the washer area. is that some kind of pressure screw? I tried to remove the 3 bolts holding the cover down but something is holding tight like a good seal on the gasket. the rhino did make a deer tuffff sound and I seen oil down there buy the valve cover. it looks like the head gasket area is dry oil is up top. and clue ???
and what is the screw at the top of the valve cover for |
took off valve aka rocker cover the gasket was torn for sure
anyone know where to buy a rocker cover gasket for the cg200 I looked and can only find one for 125cc q9 started to cover it then canceled order we will see
If it's for a Rhino then a gasket from a CG250 will fit. Use one from the TT250.
https://store.cscmotorcycles.com/TT2...p/zt37-104.htm
2025 Lifan KPT 400 2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 (Sold) 2016 Black Hawk 250 (sold) 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel |
this one looks like it will it work?
https://www.ebay.com/i/362071142607?chn=ps |
or this one but much longer shipping
cg125 gasket |
The valve cover gasket is the same for the CG125-250. CSC will be the quicker way to get one.
#10 | |
http://chinariders.net/showthread.ph...407#post298407 |
#11 | |
