Old 06-28-2019, 07:49 AM   #31
Originally Posted by brianjmt View Post
You sure on the wheel combo's? On Lifan website they have it at the 19/17 combo. But either way not sure i want to risk $$$ with this new efi. On top of that just 200(196) cc not big enough. Another genius idea from the good idea fairies. I wonder who actually makes these decisions the Chinese or some dump ass redneck American with no business experience.
You are correct on the 19/17 combo. I read the 21/18 combo off another online dealers website. I should of known the specs on some of these dealers sight are mostly incorrect. lol Don't be fooled by the 200cc engine. These engine perform as well as the 229cc engine and seen some that perform better. Ask Azule about his 80+mph 200cc.
Old 06-28-2019, 07:55 AM   #32
I did get the tire stuff sorta today and in process of making out a post with all the tire brands/models in the sizes that will work on the 19/17 combo's. I used the xs650 and the cr125 motorcycles as both use the 1.85x19. I didnt get one hang up or snobby reply from any of the shops I called. Nothing but help, Amazing!
Good deal! It's a mind set that most people have that think it's all china junk.
Old 06-28-2019, 09:29 AM   #33
pete   pete is offline
pete's Avatar
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 06-28-2019, 10:10 PM   #34
brianjmt   brianjmt is offline
Thanks pete. I like fortnine been watching his videos for a yr or so. he does some great videos.
Old 06-29-2019, 02:31 AM   #35
After doing research on the Brozz tire sizes 17/19 here is what I found. This is after researching this site, multi other forums, net, and talking with 3 major brand bike shops. Here is list of what tires are available for the china bikes with the:
OEM front rim size 1.85x19, tire size 90/90/19
OEM rear rim size 2.5x17, tire size 110/90/17
Replacement Tire size:
Front 100/90/19 will work on the 1.85 rim for the front.
Rear 120/90/17 will work on the rear 2.5 rim.
I did a search of tire manufacturer sites and here is the model of tires they make in these sizes. I did only matching pairs since I do not run mix match tires. SO if you do there are a few more options that you could mix and match.
I did find one perfect match for the OEM tire size. But couldnt fine any state side but they were listed on Michelin USA site so you may be able to order them.
Michelin Sirac 110/90/17 and 90/90/19
Second best match and china rider favorite is
Shinko 244 2.75x19 front and 4.6x17 rear
The follow are tire brands that make the 100/90/19 front and 120/90/17 Rear.
AVON - Trail Rider
Mitas- Terra force, E07, E08, MC-24, E09 (Terra Force is new and caught my attetntion I will be looking for a review on these)
Metezeler- Tourance
Dunlop- Trail Smart
Continental- Trail attack 3, Trail attack 2, TKC 70, TKC 80, Escape
Perelli- MT60
Kenda- K761, K760
Now money wise and performance wise Shinko 244 is Top dog, and under a $100 a set. The others will be much heavier especially the AVONS they are like lead. They will also set you back most likely over $200+ a set.
Hope, this helps those looking for replacement tires.
Also here are couple links I found worth a read.
https://www.rockymountainatvmc.com/d...-Tire-Info.pdf
https://dropbears.com/motorcycles/utilities/tyrerim.htm
Old 07-18-2019, 07:54 AM   #36
I went 100/100/19 and 120/100/17 on my Bashan. TKC 80’s are terrible, they skip around on the pave and cake over instantly in the mud. For dry pack dirt roads (not gravel) they do ok but will still like to wash out. They look cool though both stock tires together weigh less than 1 front TKC.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster,
Old 10-17-2019, 08:35 PM   #37
MarkLowryIII   MarkLowryIII is offline
AVON - Trail Rider
Metezeler- Tourance
Dunlop- Trail Smart
Perelli- MT60
Kenda- K761, K760
After pulling my hair out trying to find exact replacements for the tires on my Brozz 250s (mine and my son's), I come across this breakdown. I've taken a screenshot of this post and I'll share it whenever/wherever it's needed!
Old 10-17-2019, 11:04 PM   #38
GlennR   GlennR is offline
The Shinko 244 is a great tire for my dual sport needs. I push them hard through the twisties and they grip well. I wouldn't want a more street looking tire on my dual sport bikes.
Btw, somebody mentioned to beware of heavy tires. I couldn't agree more. Small engine bikes need the lightest tires you can find, because heavy tires really rob power. I found the Dennis Kirk lists the weights of each tire size of all the brands that they carry. It's very handy info when researching tires.
Dual sport tires have very soft sidewalls, so they are especially easy to change. Almost as easy as a bicycle tire.
Old 10-19-2019, 08:08 PM   #39
RevItUp   RevItUp is offline
RevItUp's Avatar
Having had both on a Hawk, I would go for the 700 every time. The 705 is great on road, but the 700 is 90 percent as good on road, and much much better off road.
Where did you find the 700’s in a 19/17 combo? I can’t find them anywhere
Old 10-19-2019, 09:58 PM   #40
Nowhere. The context of that statement was made under the assumptions of this bike having a 21 and 18 inch wheel combo.
Old 10-20-2019, 12:03 AM   #41
herbie   herbie is offline
Originally Posted by roundhouse View Post
I have about 1500 miles on shinkos 705s i am really impressed with their grip. They do pretty good on hard packed gravel but i would get maybe the 700 for looser stuff.
I have the shinko 705's in my watch list, I think this is what I am going with once my tires wear out. I have about 3000 miles on the stock tires and I think I can go about another 2000 or 3000 miles before a change out. I am glad to hear they grip well as I use my bike mainly for on road riding.
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 10-20-2019, 08:12 AM   #42
Armycopter   Armycopter is offline
Armycopter's Avatar
Peace Sports offers a knobby tire replacement for the Brozz 250. Has anyone tried it? I was thinking of giving it a go but probably not until next spring. I only have about a month left until I have to put the bike up for the winter. I definitely need some more aggressive tires though. The trails I ride have a fair bit of sand and mud and the stock Brozz tires can wash out pretty easily.
2019 Bashan Brozz 250
2019 Honda Africa Twin CRF1000L
Old 10-20-2019, 08:48 PM   #43
everready   everready is offline
Kenda Trakmasters 2, if they come in that size. They are awesome on just about everything. I run them on my DR441. The rear wears pretty fast on pavement though.
Old 10-20-2019, 11:01 PM   #44
OneLeggedRider   OneLeggedRider is offline
OneLeggedRider's Avatar
Kenda Trakmasters rock! I put one on my front and bought 2 for my buddies. Even on pavement they offer higher stability than the stock Hawk knobby because they don't tend to follow grooves. And offroad they grip like no other. The downside is more road noise and vibration because the big knobs are so far apart.
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
