04-27-2021, 11:46 AM | #1 |
TT250 Manifold
The stock carb on the TT250 bolts directly onto the manifold. The PWK30 clone that I order from China has no such bolt holes to attach it. Is there a manifold I need to order to make this all work or did I order the wrong carb?
https://a.aliexpress.com/_mN3IZ1B Thanks,
Electrician & Electronics Tech 2014 Honda CB500XA 2016 CSC TT250 1976 Honda CJ360T 2022 Honda Navi |
04-27-2021, 12:17 PM | #2 |
You will need something like this
https://www.amazon.com/Motorcycle-Un...539521&sr=8-39 You will need to know the outside diameter of the carb engine side and the offset needed for the manifold adapter so it lines up with the air intake tube, unless you are using a Pod filter as well, if you use the pod filter you will have to make sure it does not hit the frame or have any other interference issues with fitment. |
04-27-2021, 12:23 PM | #3 |
Or this version:
https://www.amazon.com/PUCKY-Carbure...%2C254&sr=1-10 This will be the easier way, I used this on my DB-05 just needed to rejet it and adjust the float level but it's been working good. |
04-27-2021, 01:23 PM | #4 |
I think you are looking for a spigot manifold like this, but I have not done the installation and don't know the particulars on a TT 250 this one does work on a HAWK I believe but sometimes there are frame issues.
https://www.amazon.com/NIBBI-Perform...NsaWNrPXRydWU= |
04-27-2021, 02:46 PM | #5 |
Usually stuff on Amazon.com won't ship to me in Canada and the selection on Amazon.ca is horrible in comparison. Aliexpress or eBay links would be preferred. The original one is bent with about a 45⁰ corner on it as well as a spot to hook up a small hose on the inside of the bend. I'll take a picture of it soon.
04-28-2021, 02:04 PM | #6 |
Seems I cannot take a picture under 0.2MB to be able to upload. Not sure when the files size limits got so tiny. I used to be able to upload pictures from my phone but I guess not anymore.
04-28-2021, 07:30 PM | #7 |
From the link you provided down the page there was this manifold shown.
https://www.aliexpress.com/item/32967821398.html |
carb, carburetor, pwk, pwk30, tt250 |
