Old 05-25-2008, 06:23 PM   #1
Komoto250cc   Komoto250cc is offline
Kink in fuel line 250cc Komoto/Hi-bird
I am wondering if anyone has had any problems with their fuel line. Recently, I replaced the cheap, flimsy black fuel line that runs from the fuel shut off valve to the carberetor with some clear rigid line. It's a lot better, but I fear that the line might kink again over time. I cut this line a lot shorter. Was that a good choice? Should I have a super long line that allows for a loop and no kink? How about a line that is reinforced with some kink of non-kinking material?
Old 05-25-2008, 09:37 PM   #2
liverchip   liverchip is offline
Send a message via MSN to liverchip
I too replaced the stock fuel line. I ran a bit long and looped it.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 05-25-2008, 11:01 PM   #3
Dragon   Dragon is offline
If you remove the fuel filter, the line will not kink.
Chinabikeless
Old 05-25-2008, 11:03 PM   #4
CRidin   CRidin is offline
If you remove the filter in time the carb wont work.
Old 05-25-2008, 11:11 PM   #5
Roketas don't include fuel filters, as I understand. They must think it's alright.
Chinabikeless
Old 05-25-2008, 11:16 PM   #6
Its just my opinion. Ive been a mechanic many years, and when younger I would try to skimp on a fuel filter. It always bit me in the azz. It may not bite right away, but it will bite. There is a sort of filter in the tank. But in my exsperience they arnt great.
Old 05-25-2008, 11:23 PM   #7
I'm not a mechanic, so just ignore what I wrote. lol. But, it is true that without the filter, the line won't kink.
Chinabikeless
Old 05-25-2008, 11:27 PM   #8
There is a filter that has an input on the top and an output on the side. That may help with your configuration.
Old 05-25-2008, 11:36 PM   #9
My kinks also. If there is a big loop, will that adversely affect the carb?
Chinabikeless
Old 05-25-2008, 11:40 PM   #10
No, thats a small loop.It wont matter. It may be hard to get it flowing if you run it out of fuel. I loop them to it just works out that way.
Old 05-25-2008, 11:41 PM   #11
warrior91   warrior91 is offline
If you use real good FUEL line it wont kink at all...
I would stay away from clear line as it dries out and cracks. I used some on my Yamaha and one year later it is not cracked but is so hard it breaks instead of flexing... black rubber nylon reinforced 3/16 FUEL line is the ticket...you must remember to get clamps to fit at the parts store because the flimsy wire butterfly clamps will not clamp anything substantial and chances are it will not even fit around the good line anyways.
I was able to fit 2, 3" long fram fuel filters on the ATC 70 to keep the rust from infiltrating the carb...2 separate lines for res. and normal on the ATC tank... no kink issues at all and very little space needed if you can find someplace handy to tuck them in and zip tie to frame...
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 05-26-2008, 08:32 AM   #12
zundapp2   zundapp2 is offline
Consider replacing the petcock with one of standard length. Cost is about $18 and there is no problem with fuel line or fuel filter. See my gallery photo.
Old 05-26-2008, 10:39 AM   #13
Here's what my fuel line looks like: [img][/img]
Old 05-26-2008, 10:39 AM   #14
How do I post an image?
Old 05-26-2008, 10:51 AM   #15
You put the http address in between the [img][/img].
Chinabikeless
