Old 08-17-2021, 05:09 PM   #1
MotorBike_mike84   MotorBike_mike84 is offline
Head Scratching Front wheel Issues
Hey guys… hope everyone is well. Ok so my X22R has recently been pulling side to side and has a bounce in the front wheel at low speeds. I thought maybe it was tire pressure. Check that and all was good, also checked the back wheel for alignment and was also good. I have no idea what this can be and it seems to be get worse. When hitting front brakes there’s a slight pull in either direct (depends on where my weight is I guess). Anyhow I’m in fear of going down the road and losing the front wheel all together. I’d appreciate any input to fix this problem or any info on where I can just by a brand new wheel. Thanks guys.
Venom X22R
Fairing Bolts (gold)
Performance levers (Gold)
Handle Bad Ends (Gold)
Rim Trim (Gold)
Custom plate holder and rear indicators
LED headlights & running lights (6000k)
LED under carriage & Engine lights (RGB)
Aftermarket Exhaust carbon fiber (Aggressive)
Aftermarket Mirrors
Decals (Removed stock)
Old 08-17-2021, 05:31 PM   #2
TheGammaGhost   TheGammaGhost is offline
Possibly wheel bearings, I would also check to make sure your axle nut is tight.
2021 Boom Vader Gen 2 BD125-10 Current
2011 DRZ400S Current
2006 LIFANIZED ROKETA DB-06 200cc Sold
2008 Ninja 250R Sold
1984 Honda aero 125 Sold
1980 Honda CM400T Sold
Old 08-17-2021, 06:31 PM   #3
TxTaoRider   TxTaoRider is offline
Sounds like the tire is out of round.
2021 Tao Tbr7 - "Lucille"
Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket
2009 Q-link Legacy 250
1982 Suzuki GS1100ES - "Jolene"
Old 08-17-2021, 06:47 PM   #4
Thanks I was thinking bearings and never even thought to check nut. Appreciate the help.
Venom X22R
Rim Trim (Gold)
Aftermarket Mirrors
Old 08-17-2021, 06:49 PM   #5
Thanks had that in mind too. Live in FL so some streets can be a “dozy”. Is there any cheap way to check??
Venom X22R
Rim Trim (Gold)
Aftermarket Mirrors
Old 08-17-2021, 11:25 PM   #6
Plump Kibbles   Plump Kibbles is offline
You can pop the front up, spin the wheel and take a look while it's spinning. I was able to put some pens (writing) evenly on either side, spun the wheel and it would mark where the high spots were on the rim. Got it done in under an hour, almost perfect! Front may be tricky to do that method, I did that on the rear.. unless you have a truing stand; which I don't. Any shop should be able to true the rim I would think - unless you're in my area. I called about that and promptly was told no when I said "it's like the Hawk250 bike"... But I kind of think it may just be out of true from the sounds of it.
|2020 X-Pro Titan DLX| <-- FOR SALE!!
Old 08-17-2021, 11:56 PM   #7
Falkon45's Avatar
Problem is, he has alloy wheels. Not wire spoked.
Old 08-18-2021, 11:46 AM   #8
That is correct
File Type: jpeg 95F8C3FF-9B08-400C-BE5A-D6BFE0699F7D.jpeg (29.2 KB, 968 views)
Venom X22R
Rim Trim (Gold)
Aftermarket Mirrors
Old 08-18-2021, 11:46 AM   #9
Does anyone know where to purchase either new bearings or a whole new wheel in itself. Save myself the hassle.
Venom X22R
Rim Trim (Gold)
Aftermarket Mirrors
Old 08-18-2021, 12:38 PM   #10
J4Fun   J4Fun is offline
I know it sounds dumb but can you verify the forks are tight on the top?
Old 08-18-2021, 01:41 PM   #11
Bruces   Bruces is offline
Have you contacted Venom ?they are one of the good dealers so they should be able to help
Old 08-18-2021, 02:44 PM   #12
Don't over think it. First check that there is no excess play in the stirring neck. If all is good and snug, the next thing i would do is deflate the tire. Rotate the tire on the rim 90 to 180 degrees. It's possible that the tire is not beaded evenly on the rim. unless you have excessive play in the axle and rim i would think the bearings are good.
Did you clean the brake rotors and pads before riding the bike? There is a shipping film on the rotors that really needs to be cleaned off. This would cause any pulsating or pulling when the brakes are applied.
Old 08-18-2021, 03:34 PM   #13
The film I don’t know about. I bought the bike brand new from a previous owner. It had 5 miles on it when I got it. It was riding beautifully until about 3 weeks ago. Rear tire pressure was major low so I thought that would be the issue.
*I have a cobble stone drive way. When I ride over bike goes all over the place. Can’t even corner on cobble stones because bike feels like it’s coming out from under me.*
Don’t know if that helps explain what I’m experiencing. Everything seems to be tight but I won’t be able to take a look at it until this weekend. I use bike to get to work so hopefully whatever it is can hold on until Friday.
Venom X22R
Rim Trim (Gold)
Aftermarket Mirrors
Old 08-18-2021, 03:36 PM   #14
I don’t have any play in forks if that’s what you mean. Was also thinking maybe install a brace??
Venom X22R
Rim Trim (Gold)
Aftermarket Mirrors
Old 08-18-2021, 03:37 PM   #15
No not as yet…. Trying my best to keep $$$$ in my pocket.
Venom X22R
Rim Trim (Gold)
Aftermarket Mirrors
