Old 10-07-2021, 06:25 PM   #1
Aufgeblassen   Aufgeblassen is offline
What Does "Sputtering" Mean? (Tao Motors TBR7)
I was informed that my new 2021 Tao Motor TBR7 may "sputter" with the stock carburetor. I have not noticed anything like that during acceleration or at steady speed. But when decelerating with throttle off, is sputters/backfires a bit. Is that it?
Old 10-07-2021, 07:23 PM   #2
buzz   buzz is offline
HI you need bigger jets,more gas
Old 10-08-2021, 10:59 AM   #3
Dusman   Dusman is offline
Backfiring during deceleration...
Backfiring during deceleration or letting off of your throttle indicates a lean pilot jet. Try going up one size in your pilot jet and see if this remedies it.
Old 10-08-2021, 12:44 PM   #4
How does it matter if it happens? Sounds cool actually!
Old 10-08-2021, 03:22 PM   #5
The backfiring is a sign of a lean idle mixture. Pilot jets is probably sized right. Try turning out the idle mixture screw to about 1 1/2 turn for a starting point and adjust from there. The idle mixture screw is located on the bottom side of the carb next to the bowl. It will have either a brass or plastic cap covering it that you will have to remove t gain access to it.
Old 10-08-2021, 05:21 PM   #6
braindead0   braindead0 is offline
Running too lean can damage your engine, that's why it matters.
Old 10-08-2021, 05:53 PM   #7
They would not design it that way.
Old 10-08-2021, 06:06 PM   #8
It's designed to run with a stoichiometric mixture of fuel/air at about a 14.7:1 parts air to fuel ratio. You're bike is running too lean, the engine is NOT designed to run under those conditions... too lean and it will be damaged.
Old 10-08-2021, 07:51 PM   #9
mototech77   mototech77 is offline
mototech77's Avatar
You are giving the manufacturers too much credit. These bikes are fine for the money, but they lack in quality control and engineering. Braindead0 is absolutely right about possible damage, and JerryHawk250 has great advice on how to resolve it.
It’s your bike though, so if you really like the popping and are okay with engine damage, more power to you
2021 Lifan Xpect EFI
2012 DF250rtc
1982 Yamaha Virago XV750
1982 Honda Twinstar CM200
Old 10-09-2021, 10:04 AM   #10
TominMO   TominMO is offline
No vehicle which is subject to environmental emissions regulations is designed for optimal running; they are designed for passing emissions regs, i.e. they are too lean. If you have a carby bike, step one should be to get the air intake and carb jetting right. If you are not concerned about water splashing onto the filter, or the intake being submerged in creeks, toss the airbox if it has one and put on a clamp-on filter. Then adjust the carb, or get a better carb, to suit the improved air intake.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired.
Old 10-09-2021, 12:57 PM   #11
But it is advertised as: *Item does not have fmvss, NHTSA label*
*Please check with your local DMV to confirm street Legality*
Old 10-09-2021, 01:24 PM   #12
Bruces   Bruces is online now
Clearly you must be right and everybody else around here is wrong .
Old 10-09-2021, 01:49 PM   #13
J4Fun   J4Fun is offline
Too listen, is too learn! Just thinking out loud!
Old 10-09-2021, 03:26 PM   #14
Ding, ding, ding! They are lean to pass the tests.
This! There are numerous members with years of experience on this site. Bruce is one of them. It has been determined with hundreds of members as unwitting test subjects that these bikes across the board as far as Chinese brands go set the carbs lean to pass the EPA offroad tests and the EPA/DOT tests. Many members have either rejetted the stock carbs (more difficult to do over the years as the carbs are more difficult to get into) or found better carbs on Amazon/Ebay which has remedied the problem.
On a side note, the LIfan X-Pect 200 and RPS Hawk DLX with fuel-injection have shown fuel-injection to be mostly reliable remedies.
Old 10-10-2021, 05:38 AM   #15
I would not look at it that way. To me, the one problem with EFI is that it is hard to change the stock settings compared to just swapping jets (or a whole carb) on a carby bike. The manufacturers make their EFI systems run lean too.
EFI is great for automatic altitude adjustment, but if it breaks it is not as simple to fix as a carby.
2022 Lifan KPX
