Old 02-12-2023, 09:07 PM   #1
Fast_Freddy   Fast_Freddy is offline
Fast_Freddy's Avatar
Templar 250 skid plate
I found a skid plate that fits the base Templar pretty well all things considered. Unfortunately they sent me blue when I ordered black so I need to exchange it but since I had it I tested the fitment and it ain't bad. The included mounting bracket works and it looks pretty good on the bike. There is a hole in the back that lines up with a frame crosstube and can be attached with a zip tie. The base Templar frame gets much wider at the foot pegs so it will fit better if I heat up the plate and flatten it a little or cut away a bit in that area.
I was considering making one from a HDPE cutting board but this is a lot less work. I wish I had a heat gun but maybe I can use a propane torch instead. Let me know what you think about the fitment.
The skid plate is Cycra SKU: 1CYC-6206-12 and fits 2010-2013 Yamaha YZ450F.
ID:	28568   Click image for larger version
ID:	28569   Click image for larger version
ID:	28570   Click image for larger version
ID:	28571   Click image for larger version
22 Templar 250
Old 02-13-2023, 07:15 AM   #2
Huck369   Huck369 is offline
Huck369's Avatar
I made one for mine out of 1/8" Aluminum, added some to the sides in front of the shifter/brake pedal, to add a little more protection.....don't have any pics, but will try to get some
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 02-13-2023, 10:11 AM   #3
GypsyR   GypsyR is offline
GypsyR's Avatar
I like it. I never thought of a plastic one for some reason. Definitely need a color swap there though.
Old 02-13-2023, 10:13 AM   #4
Deckard_Cain   Deckard_Cain is offline
I used the Cycra plate for an 05-19 YZ250.. it fits well except it needs some foam or delrin spacers in front to be able to tighten up.
https://www.amazon.com/gp/product/B0725FJRFR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Old 02-15-2023, 12:23 AM   #5
Nice. I'd like to see what it looks like when you get a chance. Learning to TIG is on my list of things to learn someday.
22 Templar 250
Old 02-15-2023, 12:26 AM   #6
If I had left the oem graphics on the blue might have worked but definitely not with the monochromatic black/orange theme. I ordered a black one today.
22 Templar 250
Old 02-15-2023, 12:27 AM   #7
Base Templar or X/M? Got any pics?
22 Templar 250
Old 02-15-2023, 10:02 AM   #8
Huck369's Avatar
Only pic I have on my pc, doesn't really show it.....will try to get a better pic
Huck
2013 Honda NC700X
2016 AJP PR4
2022 Templar X 250
AMA Life Member
Old 02-15-2023, 11:22 PM   #9
Thanks! I zoomed way in and got a pretty good look. I'd be happy with that.
22 Templar 250
Old 02-18-2023, 08:57 PM   #10
My new black skid plate is done. I had little success bending it with heat so I ended up cutting it instead. It fits pretty well with the included mounting bracket and a zip tie at the rear. It's not the best skid plate ever but it's a helluva lot better than no skid plate. I added a hole so I can change the oil without removing the skid plate. Cost: $65
22 Templar 250
Old 02-18-2023, 09:57 PM   #11
Old-dude   Old-dude is offline
Have you ridden with the new plastic skid plate? The stock plate on a templar X sounds like a bad hail storm on some loose gravel. Be nice to quiet that down a bit.
Also think it would fit over the stock plate? Nothing like double protection.
1985 HD FLT
1995 HD FXD
2000 Honda RC51
2022 Xpro Storm 125 - (grandson)
2023 Xpro Templar X
Old 02-19-2023, 12:37 PM   #12
I haven't ridden it yet but will report back on it later. Have you considered attaching some noise cancelling material to the stock skid plate? It might help. I don't know how well this skid plate might fit the Templar X/M frame. My base Templar frame is quite different.
Edit: Rode a little today and can't tell the skid plate is even there. None of that metal skid plate resonance and reflected sound waves.
22 Templar 250
