74mm big bore kit
https://aj1moto.com/products/otom-ne...raded-to-300cc
What's your opinion, 14cc/6% increase in displacement worth it? |
Being "worth it" or not would be entirely up to you.
It will have a benefit, but on its own it may not impress you a ton. If you are after power a cam will provide more bang for your buck.
Where can I source a cam?
I bought that kit (Otom "300cc" piston/cylinder).
Oh it is a NICE kit. Complete, and the machining and parts look excellent. All gaskets, orings, gudgeon pin/circlamps, piston rings. Very nice kit. But I was dismayed when I found out it was just a 74mm bore. YUP, that increases displacement by 14cc (249.99 to 264.07). I wouldn't call that a 300cc kit, even though 300cc is cast into the cylinder (see it in the photo). At least the advert you found admits it is a 264cc kit! For me, it's NOT worth it unless I also add the cam, port the head and maybe get a slightly larger diameter carb. All together, it would probably make a big difference (maybe up to 24hp). The most noticable difference might be in the midrange torque feel, and off the start torque would probably feel spunkier and more willing. So my kit will sit on the shelf until I have time to really work on it. I also got a new head and was willing to do it, but it did not come with the valves and cam (listing showed the valves/cam included). Disappointment.
No matter where you go, there you are... "It's the environment, stupid" ("No planet, no jobs" ) Last edited by Thumper; 10-24-2023 at 05:37 PM. |
I posted comments about the empty head I got from a vendor on AliExpress. Today. See post #5, last paragraph... above
My son left for work this afternoon and apparently found this on our doorstep: I can't believe it. This cleared customs back in the Spring sometime, AliExpress got notified by the vendor that it was returned, and AliExpress refunded my payment in full. Thank you ! ![]() But somehow, it came back, 8 months after I sent it off. Cool. The package is pummeled but I packed it thickly padded, double boxed. Nice to have it back. I ended up just paying the shipping. Not bad!
No matter where you go, there you are... "It's the environment, stupid" ("No planet, no jobs" ) Last edited by Thumper; 10-24-2023 at 08:10 PM. |
I wish I waited until XPro had the Zuma Templar X X7-250 head with Valve ass'y in stock. I think it is OEM. $100 on ebay!
I posted in the web deals section with a picture of the listing. I just had to buy one from a vendor on AliExpress. Impatience... Doohhh!
No matter where you go, there you are... "It's the environment, stupid" ("No planet, no jobs" ) |
#8 | |
FYI, I got the complete head with cam, rockers, valves and springs installed for $100 as a replacement part from XPro so I will go ahead with the porting at some point (so busy now, no time!)
#10 | |
One reason I picked mine. No problem with a 230 but not when it has 250 stickers all over it. Just me being picky though. 250 cc stickers on a 249cc (or 230 on a 229cc) I don't have an issue with.
Playing devils advocate here, but couldn't you purchase this kit and then have it bored out by approximately 81.06mm?
Displacement=π(pi)×( 2/Bore ) 2 ×Stroke 1. Calculate the original bore size. 2. Calculate the bore size needed for 249.99cc (74mm). 3. Calculate the bore size needed for 300cc. Might be worth it for some people. |
the 200cc* cg bikes will have the 163-FM
250cc* should have the 167-FM |
#14 | |
https://spicerparts.com/calculators/...ent-calculator Select metric, then enter these bore and stroke numbers from various listings for engines. I copied the info from 2 engines from AJ1, and 2 listings from ebay. I was surprised to find that they were all accurate claims when I entered the bore and stroke numbers on the listings. But I noticed something interesting. The Zongshen ZS174MN watercooled engine at AJ1... 74mm bore is like the OTOM kit I got, and if you use my stroke (61.4mm for the ZS172FM) you get 265cc, but if you use the stroke from the ZS174MN (65mm), you get 280cc. I think the OTOM kit assumes a 65mm stroke! Here they are: AJ1 Zongshen CB250F, ZS172FMM-3, 20hp bore x stroke 72mm x 61.4mm 249.9cc Spicer 249.99 AJ1 Zongshen CBS300, ZS174MN watercooled, 25hp bore x stroke 74mm x 65mm 279.5cc Spicer 279.56 Ebay lifan (Cleveland Cycleworks) 14hp 167FMM 67mm x 65mm 229cc Spicer 229.17 Ebay lifan 163FML bore x stroke 63.5mm x 62.2mm 197cc Spicer 196.98
No matter where you go, there you are... "It's the environment, stupid" ("No planet, no jobs" ) Last edited by Thumper; 02-27-2024 at 08:49 AM. |
#15 |
Is aj1moto legit? I'm new to the group, and have been using my 172fm-3a for a dirtbike project. Wouldn't mind exploring to other zs dirtbike motors for more power, but I've never heard of the aj1 until I stumbled upon this forum last week. Has anyone ordered an engine from them? Are they based in US or China? How does shipping work? Is it worth it?
