05-08-2024, 04:17 PM | #31 |
Venom is in the building! They've called me! As for the sound, I've sent them a clip of it and they told me to stop riding the bike. They are working with the manufacture and we are on the road for a warranty issue. In the interest of the warranty and not wanting to hurt Lifan I'm not going to upload the video. I understand things happen, it's normally a one off, but this is the world not a video game.
05-08-2024, 04:22 PM | #32 | |
05-08-2024, 06:33 PM | #33 | |
My "primitive" carbed bikes can't adjust automatically for elevation/temperature. Nothing over 500 feet in evelation within 500 miles of here, but I will be moving. So I will rejet accordingly. You can do that with a carburetor.
06-11-2024, 04:46 PM | #34 |
KPX noises and what's new
In regards to the noises and engine issues we emailed about here is what I got. After putting 200 miles on this bike I have accepted the minor noises that the engine makes and I am ok with it because of this quiet riding bike that has no muffler noise and you can only hear the engine, and that is ok with me. There is no detonation and I can only attribute the noises to engine vibration. As far a adjusting valves if you read the service manual you will easily find Top Dead Center easily by viewing the flywheel location and timing sprocket. I did this just to check the chain tension and it ended up ok. I want to add that I changed the oil at 50 miles on the odometer with the recommended oil and filter and yes the metal flakes were obvious. Riding with the this stock rear sprocket it is somewhat of a dog and in 2nd and 3rd gear cruising the local streets at 25 mph the transmission sounds whiney and tolerances may be the issue, but who cares , I don't. As far as the throttle response the re-flashing worked to some extent but, not great. I felt if I gave it a go at the TPS it might help and by ordering a test harness off Ebay ( see pic ) I was able to check and adjust the TPS value from .650 - .850 and it really isn't doing much. The service manual TPS value for idle is about .600 and I have tried several values and still not perfected. I am interested in swapping out this carb and then call it quits. I am ok with this bike and this is a lot of bike for the money but, here is the fact Jack. If you have ever rode a Honda, or Suzuki like I have you will not like the quality or power range of this bike. It is cheap, the parts are cheap, and the price is cheap. You get what you pay for and I again am impressed that someone can build a 250 for this price and make a profit. I will ride it most likely for another year and hopefully trade it in for a real bike.
06-12-2024, 01:47 PM | #35 | |
