Old 05-09-2024, 06:49 AM   #1
jatgm12   jatgm12 is offline
Where can I get shark 250 front brake caliper
So I have this 17" 19" Chinese enduro that has a single cylinder front brake that looks like the posted pictures and I'm trying to find a replacement. It's a shark 250 enduro. Where can I get one that will work?
Old 05-09-2024, 06:57 AM   #2
https://ibb.co/qRF2rQk
https://ibb.co/Xb7DV6h
These
Old 05-09-2024, 08:02 AM   #3
Look here. https://www.vmcchineseparts.com/coll...brake-calipers
Old 05-09-2024, 09:36 AM   #4
Do you happen to known which version it is? I don't see any that look exactly the same and I'm not sure how to see if it's the same.
Old 05-09-2024, 01:07 PM   #5
https://www.vmcchineseparts.com/prod...-taotao-db10-1
Is it this one if taken off the mount? Because the bolt spacing is not 2.4ish inches on this one.
Old 05-10-2024, 01:37 AM   #6
I can't even find that style for the front. I almost wonder if it wouldn't be easier to change out for a 2 piston caliper like the Hawk and other standard fork bikes use. The mounts on the fork lower may be the same. I could measure the spacing of mine to see if it is.
Old 05-11-2024, 11:18 AM   #7
If you could measure that would be cool.
Can I use a two piston one for this disc? Is it compatible? Which one should I use? I'm a bit confused really.
Old 05-14-2024, 02:50 PM   #8
Any idea if the hawk front brakes would mount?
Old 05-16-2024, 01:20 AM   #9
No clue, but the bolt spacing on the forks of the Hawk is 2.4 inches/61mm (roughly) from center to center.
