Old 04-19-2009, 02:42 PM   #1
daddy469   daddy469 is offline
Mono Shock adjustment
Is the rear shock on these bikes adjustable at all? Mine seems a bit 'soft' (or I'm a bit soft 8) ) Anyway, thx!
Daddy
The Great Eye is ever watchful
Old 04-19-2009, 04:00 PM   #2
Frog   Frog is offline
Hi
yes it is - or at least mine was. Mine adjusted for spring preload via a threaded collar at the bottom of the shock.
BUT when adjusted to take my weights the damping was non-existent - all spring and no damping. My answer was an early CBR600 shock............ other have fitted others shocks.
Frog
Old 04-19-2009, 09:30 PM   #3
Originally Posted by Frog
Hi
Frog
Hmmm, I've been wondering about this myself. Which model bike do you have Frog?
seer
Old 04-19-2009, 10:22 PM   #4
ya, I got 'under' it today and I saw that there was a spanner collar at the bottom of the shock, but usually they are set preloaded so I didn't want to screw with it until I heard from someone. What year CBR did that shock come from?
My license plate frame thingy broke off my bike today. I'm just glad I was on a country road with no traffic so I could get it back without risk to my person .
Thx a ton fellas!
Daddy
Old 04-21-2009, 03:05 PM   #5
Hi
I have a Lifan gy5.
Shock was from (I think) a 1991 CBR600 - the one without a remote reservoir (although I guess they may fit also) it is made by SHOWA. It is 12mm longer than standard but that is not a problem to me.
NB the bolt holes on the CBR shock are 10mm - if your bolts are 12mm you will need to weld thick 10mm washers to the frame mounts and get a couple of decent 10mm bolts.
I like my shock but note that others have had some success with the yam R1 shock.
Frog
