Old 06-04-2015, 03:33 PM   #3646
NoVa Rider   NoVa Rider is offline
Worked for me as well: Thanks for setting this up.
But it reminds me of Risk. Orange is taking over the map!
Old 06-04-2015, 04:18 PM   #3647
Originally Posted by Huck369 View Post
I got one started in a new thread....go here...
http://chinariders.net/showthread.php?t=14785
Good work, Huck. We are certainly blessed to have an lot of intelligent, helpful members on this forum from all over the world, and now we can see where they are located.
I always enjoy your intelligent, helpful posts, and your creation of this world map is another great contribution.
Old 06-04-2015, 04:19 PM   #3648
Of course orange will fill the map of the world, because it is the fastest color.
Old 06-04-2015, 04:26 PM   #3649
Huck369   Huck369 is offline
Huck369's Avatar
Thumbs Up
Thanks Spud, I try to be helpful...
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 06-04-2015, 04:48 PM   #3650
G19Tony   G19Tony is offline
G19Tony's Avatar
Blue added. Blue is the fastest!
Honda CB300R ABS
Old 06-04-2015, 04:53 PM   #3651
Veteran   Veteran is offline
Veteran's Avatar
White and Blue added
Bandon Oregon.
Old 06-04-2015, 05:05 PM   #3652
Old 06-05-2015, 01:47 AM   #3653
Miqueas   Miqueas is offline
Originally Posted by rjmorel View Post
Miqueas, Were you able to get this figured out ? rj
Nope, I left the bike for second time in Zongshen dealer today. The first time, they told me they fixed, but it was exactly the same. This second time I don't know but my hopes are not so high. Tomorrow I will know...
Old 06-05-2015, 02:13 PM   #3654
rjmorel   rjmorel is offline
rjmorel's Avatar
fork seal driver available
I had to change a leaky fork seal on my Rx3 and didn't have a seal driver for the 37mm size so I went ahead and made one. If anyone needs to do their seals they are welcome to "barrow" it. I believe CSC has one also and may loan it out if someone needed it. I'm in Washington state . rj
Old 06-05-2015, 02:47 PM   #3655
You do nice work, RJ. Thanks for posting the kind offer to help your fellow RX3 owners.
Old 06-05-2015, 05:18 PM   #3656
That's impressive machining.
Old 06-06-2015, 02:00 AM   #3657
I picked up my motorcycle some hours ago, and it looks different, they say it's gonna be less heat. And change some part.
What do you think? Why is there two different versions of the RX3?
How my bike looks NOW
My original bike look
That tube is way too different. Is it better? I haven't tested yet on the highway, it was too late to go ride here.
Old 06-06-2015, 03:02 AM   #3658
rjmorel's Avatar
[QUOTE=
That tube is way too different. Is it better? I haven't tested yet on the highway, it was too late to go ride here.[/QUOTE]
Looks like they put on the same stainless steel header pipe that we get here in the USA. It's an upgrade so should be better, rj
Old 06-06-2015, 03:51 AM   #3659
I agree with RJ. You got the upgraded, stainless steel, exhaust header.
Old 06-06-2015, 12:43 PM   #3660
Yesterday, I was heading out for a ride, and the bike stalled several blocks from my home. I turned the key off/on for three cycles, as described in the link below, to get a diagnostic code from the ECU.
http://www.chinariders.net/showpost....8&postcount=17
I received fault code 0351.
After a minute or so, I got the bike started and rode back home. I looked up the fault code, and discovered I had a problem with the ignition coil. I examined the ignition coil for damage, and tested the connections leading into the ignition coil, and at the spark plug. The spark plug connection was a little loose, so I pushed it down all the way. The bike started, and I went for 120-mile ride without any further problems.
If you haven't already done so, I suggest you check to make sure the spark plug cap is fully seated.
Search this Thread:
Advanced Search
Display Modes
