#31 |
I actually pulled the forks off last nite to added 10W.
I poured them out first and measured how much oil was in each and both were at exactly 250cc's. Put the same amount back in.
[SIGPIC][/SIGPIC] Parker74 |
#32 |
I didn't measure my used fork oil. However, I can testify my forks work much better with 330 ml of Mobil1 Synthetic ATF in each fork.
#33 | |
![]() Have you noticed any difference since doing it. I have now had chance to test mine and it feels much the same, perhaps a slight improvement. ![]() |
#34 | |
![]() But there maybe a few who wish to do a fork service etc. and maintain the original factory setup after a fork oil change. I'm starting to wonder if this is possible with 330cc of oil no matter what the grade. ![]() ![]() |
#35 |
I didn't decide on 330 ml of for oil, myself. I merely followed the specification listed in the CSC maintenance tutorial for fork service.
![]() http://www.cscmotorcycles.com/Articles.asp?ID=263 I also know from seven years of experience studying, and working with Chinese motorcycles, that the forks are almost invariably low on oil as configured at the factory. ![]() ![]()
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." ![]() 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 10-27-2015 at 01:28 PM. |
#36 | |
Is this a necessary step if all you are going to do is swap the oil?? |
#37 |
A lot of oil is stored in the cartridge. If you want to get the oil out of the cartridge, yes, this step is necessary.
#38 | |
Might have to do his all over again. Damn.. |
#39 |
I'm sorry to bear the bad news, but I'm betting there is a lot of oil in the cartridges. Even if you don't get 330 cc of oil when you empty the cartridges, I still suggest you follow the CSC specification.
#40 |
Thanks for the feedback! We pulled the forks back off today and after removeing the spring and pumping the internal shaft many times and pouring the old oil repeatedly I was able to get much more oil out of the forks.
Just about 330 cc's ![]() The frontend feels much firmer and less dive when braking.
#41 |
You're welcome.
![]() You experience corroborates mine. I knew the forks would perform much better with 330 cc of heavier fork oil. ![]()
#42 |
Anyone have new info on aftermarket fork springs ?
#44 | |
#45 |
Just a question reviving an old post.... would changing the stock oil be a bad idea for me, as I weigh 165, but occasionally ride 2up. Also, would the Mobil 1 ATF or the lighter Valvoline ATF be better? Lastly, after reading this thread and tutorial, would I remove the spring and pump the forks until 330ml comes out, or it's empty? If i don't get 330ml's out, I would just replace with the amount removed.
Ive not done fork oil before. Thanks all! |
