Old 09-20-2018, 09:04 PM   #121
Lucastheking   Lucastheking is offline
Originally Posted by Chinabike View Post
Its the hose that comes out of the top of the engine. Its connected to the emissions/air box.
If you remove air box then you put the uni filter on the end of the hose that was connected to the air box.
Would take a pic for you but i'm not around my bike.
OOOHH its when it remove the airbox? thanks man i havent done that yet cause i still have the stock carb on ill do it when i change the carb then, thanks man
Old 09-21-2018, 06:56 PM   #122
Chinabike   Chinabike is offline
yes only when you remove the air box, then you will have the filter on the the crank case hose.
Old 09-30-2018, 06:47 PM   #123
Help!
I can't get me rpms higher then 6-7k topping out speed 50mph wot.
After moving from a 105 main jet to a 95 main jet. Needle clip middle.
vm22 carb
when i had a 110 main jet in it would get 58mph but would bog at 3/4 throttle
Whats should i try, think i'll try back up main jet
Old 10-02-2018, 01:41 PM   #124
wlfpck   wlfpck is offline
Where are you located? I'm running a 110 or 115 main.
Have you done a plug chop to see if you're lean or rich? That's probably where I'd start.
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
Old 10-05-2018, 07:11 PM   #125
cali, yeah i was running rich at #115 #110. #105 was still a little on the rich side.
I'm running good now at #100 still need to run it some more. I think changing my pod filter mess up my tuning.
Old 10-15-2018, 03:33 PM   #126
Gman828   Gman828 is offline
Guys, had my TaoTao on the road for about 2 weeks and it has started no idling. Any idea what may be going on? Made a video to show what it was doing but can’t figure out how to upload it.
Old 10-15-2018, 06:43 PM   #127
Whisky   Whisky is offline
Whisky's Avatar
I found out that fine tuning the idle is best where the throttle is mounted on the handle bars. After u get it smooth there then set it on the carb. I fought a high/low/no idle for days.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 10-16-2018, 06:28 PM   #128
No idle? You check the plug? rich/lean.
Upload the video to youtube and post the link.
Old 10-29-2018, 12:04 PM   #129
Open the carb up and check the pilot jet. If it's clogged, could be an issue.
Throw the video on youtube and post the link.
2020 Honda Grom
Search this Thread:
Advanced Search
Display Modes
