01-15-2019, 10:40 PM | #16 | |
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 01-16-2019 at 07:44 AM. Reason: Added picture |
01-16-2019, 11:02 AM | #18 |
Good call for most bikes but the Hawk doesn't come with a kick stand switch.
02-26-2019, 08:52 PM | #20 |
I communicated with the helpdesk at Killer and they told me the Hawk will only start in neutral, The referred to the owner's manual and said they talked to the factory. My response is BULL FEATHERS!!! I asked them to explain the switch on the clutch and the wires plugged into it.
I installed my new digital instrument cluster this weekend. Of course you have to remove the headlight and old cluster. Guess what I found? A single barrel connector unplugged. I found the mate and plugged them back together. When I finished the install and had the bike all put back together, I tried to start it in gear with the clutch pulled in. VIOLA!!!! So much for expert support. By the way I love Matt's digital cluster!!! |
02-27-2019, 12:49 AM | #21 | |
Yeah the wiring behind the head light gets messy |
02-27-2019, 01:13 AM | #22 | |
if there is a diode where you put it... the starter button is feed with AC current from the rectifier.. not DC from the battery as you have it drawn.. unless the start button is very big and can handle the DC amp draw..
02-27-2019, 07:58 AM | #23 | |
02-27-2019, 09:54 AM | #24 |
the start button on these is fed DC, because they actuate the solenoid that does the heavy current Pete, AC power would only be occurring when the bike is running...
