#31 |
Called Q9 and they're not being very helpful so far...
Double checked the valves... Don't what else to do. Here's a video, it's puttering more consistently. Airbox, exhaust is disconnected. Carb has to be wide open... In the video I start with no choke, then choke and half choke (which don't putter at all), then throw the choke back off. When I give it gas you can see gas shooting out of the carb, hear the backfiring, and I saw flame come out of the exhaust port. Guess I either have to take the motor apart or prove to these guys half way across the country that something's wrong internally... buyer beware I guess. Thanks for the tips guys. |
#32 |
I might have missed it, but how is the carb jetted? When I did the first start on my Apollo with the stock carb the cat did glow a bit. But after the first heat cycle it stopped.
When you pulled the plugs, how did they look? Have you tried to increase the idle a little bit to see if it will hold idle? Are the last two videos using the Mikuni Carb? |
#33 |
So the bike is doing this with both carbs. The carb is the last video is a mikuni with a 110 main, fuel mix backed out 2 1/2 turns, and I've messed with the idle a bunch.
New plug just yesterday morning, when I pulled it out today it's black, but still sparking. Jeffrey, I honestly can't imagine how that would help. I'm no expert and I may do it out of desperation... but if there was a vacuum leak there, wouldn't it be running lean? Therefore running better with airbox connected and choke on? Not backfiring? As of now it seems to be either running rich or not burning the fuel properly. Plus, I took it off and inspected it and the gasket. It looks fine. |
#34 |
Alright I'll give it a shot.
#35 | |
Any idea what size the pilot jet is? Have you tried with the air/fuel screw 1 turn out? What is the needle clip setting at? |
#36 |
Pilot is stock on the mikuni, not sure. But when it's on the hawk it runs like a dream so there's no way there's that big of a discrepancy. I have messed with the air/ fuel but like I said the carb works on the hawk so can it really be that much different? I mean, it runs like a freaking dream on the hawk. Starts up, idles, very responsive. Same with the stock carb, which is for sure not running rich as we all know. Needle is right in the middle on the mikuni. I don't think it's the carb.
#37 | |
I would be interested to see what you are able to find with the cam timing. I agree, if you can swap the carb, and it runs great in the hawk I think it's time to move on. Also, if you are running super rich it can cause the cat to glow. |
#38 | |
One thing I forgot to ask previously was, did the cat glow so much when you tried the Hawk carb on it? Or is that something that has only happened with the original carb? I ask this because small details like that are important. With so many suggestions and trouble shooting steps being throw around it is easy to miss stuff. Sometimes it helps to just go back to square one, examine all of the evidence, and check off all the boxes. Swapping so much around and not noting changes, or having enough time to notice any changes can lead to confusion. I think we can rule out ignition as far as the plug and coil are concerned. We can rule out valve lash. We can rule out the intakes - they were both swapped around as well. I know this can be completely frustrating, so lets just put everything back to square one, clear our heads, and work with what we do know.
#39 |
I'm turning the crankshaft counter clockwise when you are looking for the compression stroke right?
I double checked it again this morning and they're spot on. The cat was glowing with both the stock hawk and the Mikuni. Both of those run on the hawk perfectly, and as of now the exhaust isn't even attached and the engine behaves the same. I was hoping it would be easy to just take a couple covers of the engine and see if it's not on time but I can't even see where I'd be able to get at the cam sprocket. |
#40 | |
How does the compression check or feel? When you kick start the hawk vs the TBr7, do they feel about the same? Dan and Jerry, if the spark timing is off could it cause the engine to behave this way? On these engines, can the spark timing be adjusted? If the cam timing is off, I would think this would need to be handled with a warranty. Johnny, try calling TaoTao direct to see if they would be willing to offer a warranty. I'm thinking it should not be this hard to get the bike to run. You have verified to have all the ingredients to make it run. With what you have done already, I would be looking at the actual cam timing, spark timing, and compression as the next move if I were in your shoes. Tao Motors # 909-614-1661 |
#41 |
Thanks, Douglass.
If the Q9 guys don't get back to me with something satisfactory tomorrow then I will call Toa tomorrow or Monday. I should have a compression tool but I don't. Although when I kick it over, it feels plenty tough. I'll keep y'all updated ! Thanks for the support. |
#42 |
Fwiw, that does sound awfully similar to when I assembled a Honda 200cc ohc engine incorrectly, timing chain sprocket was not bolted to cam right. Which I could see that allowing unburnt fuel causing the cat to glow.
#43 | |
The ignition timing is fixed as far as the pickup at the flywheel is concerned. The flywheel is keyed, so unless they key is missing, it can't shift. The pickup bolts to the side case and tabs into place. In theory it could be slid on the bracket, but they are generally bonded. There is a chance it could be a bad or shorted pickup signal going to the CDI causing it to misfire. A timing light can be used to verify the actual ignition timing. When rotating the engine, just before the T mark is two lines and an F, this is the ignition timing marks, and the slot in the case used to line up the T is also the point of reference for ignition timing. In order to check the cam timing you would need to remove the flywheel and starter gear on the crank. On the crank is the pinion gear that drives the camshaft, and above it will be the camshaft (bigger gear). At TDC on compression there is a dot on each gear that should line up to one another at the point of contact between each gear. If the cam gear is not set properly and needs to be removed, the cylinder head and cylinder would need to come off, then you can remove the center pin for the camshaft and re-install it. Given all of the things that have been swapped and all of the same issues as a result, I would definitely say either the ignition or cam timing is off. Given that the CDI itself was swapped with no change, if it was an ignition timing issue it would have to come from the source. It would definitely explain the motor trying to fire and just coming to a stop as well. If the ignition is too advanced at start up it can explain the hard start and the random sudden stop of the engine cranking when you can clearly hear it try to fire. Hopefully TaoTao can work with you directly and get this figured out.
#44 |
Just an FYI. Toa motor will not deal with me directly.
I talked to the tech at Q9. The guy gave me a pretty vague answer which in short states: "I'm not really sure what the warranty entails, or how they will determine the engine is internally dysfunctional, or how they will want to handle the situation if and when they do determine that... I'll get back to you at some point" This has left me a little disheartened. Of course I will give them some time but I'm worried that there's no incentive on their part to come through. I payed with PayPal so I'm not sure if I have any recourse through them... At this point I'd rather just box the thing back up in the case and return it. |
#45 | |
