09-06-2019, 02:42 AM | #1 |
Lights aren’t working
Hello I need help figuring out why my taillight & headlight (high & low) don’t work. The headlight and taillight only turn on if I push the “pass” button. Brake light works when I push brake. I ran DC to the taillight to make sure the led works and it does. I inspected the entire harness and the wires look good.
Thank you 2018 Razkull 125 Last edited by Vaddy416; 09-07-2019 at 03:43 AM. |
09-06-2019, 06:43 AM | #2 |
[QUlush brake. I ran DC to the taillight to make sure the led works and it does. I inspected the entire harness and the wires look good.
Thank you[/QUOTE] |
09-06-2019, 03:56 PM | #3 |
So... is it working now?
09-07-2019, 03:42 AM | #4 |
No lights still aren’t working. I was told that it could be the voltage regulator? I’m going to swap it out and see if that fixes the problem.
09-07-2019, 04:58 AM | #5 |
Uhm, is the bike new, or new to you , or have you had it a while? the reason i ask is, there is a switch that controls the headlights on the throttle side that most motorcycles dont have , they just have the one on the clutch side of the bars.
might want to try moving that switch on throttle side and checking to see if it starts working. with all your other lights working , i'd trace the headlight tailight wires inside the headlight housing , there is a connector in there that is fairly easy to disconnect it might have come loose.
headlight, light, taillight |
