Old 08-19-2019, 12:24 AM   #1
NzBrakelathes's Avatar
New versions of digital cluster TBR7 Hawk and the like.
Few details for those who need it.
More info to come.
Very universal and suits ANY Hawk like bike etc.
Old 08-19-2019, 11:28 AM   #2
duck9191   duck9191 is offline
Ill try and find my documentation i made when i did my storm so you can add it, pretty sure it was the same as the brozz for the most part.
2020 Triumph Tiger 900 rally.
2018 Bashan Storm 250. pz30b, digital cluster + gear indicator, unifilter and car customs full exhaust.
2019 Taotao 110b boulder atv. The "arm breaker" lol
2007 Honda VTX 1300R.
1974 Suzuki tm125, work in progress
2001 Suzuki Drz 400s.
Old 08-19-2019, 07:40 PM   #3
It’s kinda logical and easy
I’ll add pics n my pros n cons for each
Old 08-19-2019, 11:33 PM   #4
Bross style:
Pros:
Has a button to switch between odo & trip
24hr clock
Fully program parameters like tire or mile or km pulse etc
7 color backlight options plus brightness control
Easy fitment Hawk TBR7 and the like.
Tire circumference 150-250cm adjustable by 1cm increments so accuracy isn’t a worry to many wheel sizes
4 magnetic pulse speed sensor better refresh rate
Extra power output connection and plug for diy usb add on or other.
Cons:
Menu isn’t stacked as user friendly as it could be
Button has a little red wire showing
No volt meter no option to use fuel gauge as volt gauge
TT Style - can use fuel as volt gauge, has digital volt display after trip meter and 7 color back light etc
Old 08-20-2019, 07:34 PM   #5
nmann23219   nmann23219 is offline
Where can I buy? I bought the one that Motocheez uses and it doesnt work with the TBR7.
Old 08-20-2019, 09:09 PM   #6
Instagram
Same username
You’ll see me pop up on his instagrams too
Old 08-21-2019, 10:42 AM   #7
You didn’t buy the one Motocheez used.
You got this one and I know where they come from in China, I didn’t go with this factory for several reasons
https://rover.ebay.com/rover/0/0/0?m...2F333227191734
How ever I did get a sample and I did fit it to a TBR7 and accuracy tho not perfect it was acceptable.
It’s very important that you don’t mix your info and there for make others look bad etc.
Old 08-31-2019, 11:04 PM   #8
Promo for September
Free upgrade on shipping
https://www.instagram.com/p/B12lwNqn...d=s9hma0t8iiid
File Type: jpg 5D4B7976-E338-4798-8B94-FC4F106309CC.jpg (19.5 KB, 2716 views)
Old 09-15-2019, 10:15 AM   #9
Bashan BSR DB-41H Enforcer - Bashans Hawk like bike I found out the pin out is the same as:
Bross
TBR7
Sending a unit to the customer tomorrow and no doubt will get feed back soon
Old 09-15-2019, 06:42 PM   #10
AresROC   AresROC is offline
AresROC's Avatar
It's Bashan BSR DB-41H aka Enforcer/Hawk 2 etc... lol
Thanks for providing all those useful information it should make the upgrade process much easier!
Writeup to come BSR Chronicles
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D
JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair .
Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2
BSR Chronicles - "Project leads to more projects!"
Yamaha WR250R
Suzuki GSX-R 600
Old 09-22-2019, 09:23 PM   #11
See it’s not hard at all
File Type: jpg 39B6D1DD-083E-475E-907F-CB60E76BF7F0.jpg (10.7 KB, 2891 views)
Old 09-23-2019, 10:44 AM   #12
Can you get a wheel speed sensor to make this work on the Magician?
Old 09-24-2019, 02:04 AM   #13
Only if you invest $2000 into making it or use a universal type sensor and magnet
Old 09-24-2019, 06:04 PM   #14
I will check out the universal sending unit when I get a chance.
Old 09-27-2019, 07:19 AM   #15
I wish ppl would leave feedback on eBay
80% don’t sadly
File Type: jpg 298BD29E-A6AF-4C86-9F9D-994EADA90902.jpg (13.8 KB, 2459 views)
Search this Thread:
Advanced Search
Display Modes
