#16 |
God bless him. Power Secrets is one of my favourite books. It might be time to read about his long connecting rod theories again.
#17 |
Weld, I am in total agreement! Smokes was a lot of good things racing wise, but a small block chevy building genius
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking |
#18 |
This topic could support another thread for me. I love how he had figured out that a 6" rod and a 1.72:1 rod/stroke ratio could rev to the moon and not come apart. The early SBC 302 was closer to 1.90:1, but I seem to remember that was pushing things too far.
Sorry for the threadjack.
#19 |
this is nearly impossible where I live. I would be as much of a road hazard as the cyclists and I can't get 2 miles form my house before being on 55mph roads.
-whatever you do, just be awesome. - 2008 Kawasaki Versys - 2016 CSC TT250 |
#20 |
good thing the chinabikes are inexpensive then, eh ?
#21 | |
never had a problem with mototune method of break in on cars, I've never personally met anyone who had the patience to follow a factory recommended break in and doubt most used bikes had it followed either.
for the TT it will probably be broken in similar to described here. -with fresh oil, on and off the throttle accelerating and engine braking getting incrementally harder on the throttle and higher into the rpm. -cool down, then spend a couple hours at lower speeds riding off road. -then cool down oil change and hit the roads like I normally would, just no long distance endurance runs on the highway for a while. 20 minutes here and there should provide some good heat cycling. while commuting to work, but its going to have to deal with speeds over 55 for about 10-15 minutes at a time. Quote:
#22 |
Not true! The Tao Motor TBR7 comes with "shipping oil" that is NOT supposed to be used WHATSOEVER, according to the Manual. Should be drained and replaced with real oil.
#23 | |
#24 | |
Dude, you're replying to a thread that's over 5 years old. Who knows what the manual said back then. I know you're excited, but you don't need to take up the entire first page of the forum. |
#25 | |
