01-10-2022, 10:03 PM | #46 |
Possible plug options for the CPR8EA-9 and CPR7EA-9. The 7 is more available at your local parts store. As always, double, triple check.
NGK CPR8EA-9 replacement spark plugs Bosch 0242050506 Bosch UR4DC Bosch UR6DE Brisk AR12YS Champion P-RG6HCC Denso 4126 Denso 5362 Denso 5734 Denso IU01-24 Denso IU24 Denso U24EPR9 Denso U24ESR-N Honda 31916-KRM-841 Honda 31916-KRM-8410-M1 Honda 31916-KRM-8413-M1 Kawasaki 920700029 Kawasaki E920700029 Yamaha 94700-00866 Yamaha 94701-00415 NGK CPR7EA-9 replacement spark plugs Bosch UR6DC Brisk AR14YS Champion 8698 Champion RG6YC Denso 4174 Denso 5361 Denso IU22 Denso U22EPR-U Denso U22EPR9 Denso U22EPRU Denso U22ESR-N Honda 31917-KPH-901 Kawasaki 920700022 Kawasaki E920700022 Yamaha 94700-00420 Yamaha 94701-00420 Yamaha 94703 00420 Yamaha 94703-00420 Yamaha 9470300420 |
02-23-2022, 11:05 AM | #47 |
Anyone found a good bag solution? I know there are some for the KPM on Yoycart but I'm gonna pass on those.
2021 Lifan kpm 200 1978 Honda cb550k - in various stages of being rebuilt |
03-17-2022, 07:02 PM | #48 |
Is there any way to move the gauge cluster to the handlebars? That's a really poor design decision to put it on the gas tank, so far below your field of vision.
If you can't move it, maybe it can be disconnected and an aftermarket gauge cluster can be used? |
03-18-2022, 07:30 AM | #49 |
Unfortunately, it can't be moved. To account for speed, I just use my phones GPS. A universal cluster could be used, but you'd have to extend the wires and make a bracket to hold the cluster.
03-22-2022, 01:10 PM | #50 |
I found a guy who is producing exhausts Since it seems like neither Lifan nor KPMoto are going to restart production this may be a good option. Don't know anything else about it though.
http://lifanpowered.weebly.com/products.html
03-22-2022, 09:54 PM | #51 | |
2021 Lifan KPM 200 2019 Venom BD578Z E-Vader |
03-23-2022, 07:58 AM | #52 |
Nice. Those like a lot like the KPT200 exhausts.
03-23-2022, 11:50 AM | #53 |
Does anyone know of a clip on adapter plate that fits the KPM 200?
03-23-2022, 03:24 PM | #54 |
As in for the handlebars? I've tried a couple. One for the MT-07 and one for the Ninja 650. Neither one matches up exactly. There will need to be some milling needed to get the bolt holes to match up exactly.
03-24-2022, 04:35 PM | #55 |
FYI:
I can confirm the CR8EIX spark plug works as it should on the KPM200, its just NGK's iridium version of the stock plug that comes with the bike so no surprise. I am still breaking the bike in (<200 miles) so I cannot attribute any noticeable improvement. I thought Id stick the original plug back in one day after I have 1k or more on the clock and see if there is a difference. Has anyone confirmed a decent set of upgraded levers that fit, not just shiny anodized but actually nice quality brake and clutch levers?
"It's all falling apart like a Chinese motorcycle" - Rodney Dangerfield as Larry Burns 1975 Honda CB750K 1975 Honda CL360 2020 Lifan KPM200 |
04-12-2022, 10:59 PM | #56 |
Received the exhast from "Lifan Powered Store" and it's as good as I had hoped for! the new exhaust with the muffler weighed in under 5lb and has a 35mm diam header pipe where the stock was 11lbs and 28mm!
I just used an app for contrast as they are not accurate but unbaffled it is a LOT louder. I'm probably going to either baffle this muffler or swap it but that might be hard to do as it sounds incredible.
04-17-2022, 10:10 PM | #59 |
The power band with the stock exhaust was very obvious building from about 4900 and dropping off abruptly around 7800. This new exhaust with the straight thru muffler it was drastically more linear starting around 4k and pulling smoothly into the low-mid 8's.
04-17-2022, 10:20 PM | #60 | |
Well I did in fact do that, bought this baffle from Amazon so it would arrive next day because the straight-thru really was too loud for me (seemed louder than my ZX-7 with a Micron). With this baffle in it toned it down signifigantly at idle/rev and I think I'll be happy with this setup.
2021 Lifan KPM 200 2019 Venom BD578Z E-Vader Last edited by dr99miller; 04-17-2022 at 10:22 PM. Reason: Grammar/clarity |
