#16 |
I'm guessing the 14/39 may cut the torque too much.. i know that there is diminishing returns in some cases where gearing down too much and the bike has trouble maintaining speed at the top end. I'll have to see how the 13/42 does and then maybe go 14/42 like i have in the Titan now..
#17 | |
Actually, I can just swap the entire wheels. They are identical! But before I put the wheel back on the 2022, I should drop some off of those 49 teeth... Maybe try 42, as you have, or keep it more geared down. Or something in between like 44. The 2022 doesn't have the counterbalancing, but you don't notice that much off road. The 2022 1/2 will probably have better road manners with that smoother engine, and 6th gear. |
#18 |
I have been going back and forth on whether to get this or the KPX 250. I plan on putting a smaller rear cog on and maybe a more dual sport oriented tire. I like the weight, adjustment options and the build quality you've mentioned, not to mention the big price difference. The only thing I'm not sure about is the carb. I live at 2500 ft elevation and plan on riding at higher elevations. Will I be happy with the carb as is or should I plan on rejetting or upgrading it?
#19 | |
#20 |
Given your elevation needs, IMO get an EFI bike, period. Plus the KPX already has dual sport tires, and you may find the gearing right without any changes. EFI is reliable, low to no-maintenance and very adaptable.
Here's some discussion of rejetting for altitude, both for and against. https://www.klrforum.com/threads/car...ltitude.54394/
#21 | |
#22 |
Gonna slightly revise my opinion. It depends on how much elevation change you will be doing, and how often. If you're just going to do trips like this only rarely and you really prefer the Templar, then get the Templar. But if you will be significantly changing altitude fairly often, get the KPX.
#23 |
Thanks for the feedback. I could potentially be riding up to 7000ft to 8000ft in elevation during a one day ride from home and even higher if I do some road trips I have in mind. I'm mostly having a hard time justifying the $1100 price difference when the primary difference is EFI. EFI aside, I like most of the Templar features better.
#24 | |
![]() Now adding an oil cooler, that might be a good idea for slow trail climbs! ![]() |
#25 | |
*item 334527584998, Description: "Carburetor Main Jet 10pcs/Set Slow/Pilot Jet Kit For PZ30" Vendor is shmoto. They arrived in TWO days. Original 120 main, 40 pilot installed 125 main, 42 pilot (45 was too rich, didn't need choke in cold weather!) Last edited by Thumper; 01-23-2023 at 06:41 PM. |
#26 | |
#27 | |
All of this scary talk about elevation changes is a bit overblown. Last edited by Thumper; 09-02-2022 at 10:21 PM. |
#28 | |
#29 |
I thought I had melted my ground wire so I replaced my wiring harness. It turns out it was a faulty starter (which I fixed), but while I was at it, I got a new set of led sequential turn signals. I just tried the in the back. Maybe I will save the other two for now. Just under $20 from amazon. Sweet!
I also replaced the battery with an 80 CCA bigger battery. It barely fit, but much more power! |
#30 |
Adding on to Thumper's excellent post.
I have ordered all the tools to grind off the blind break off bolts. Of course waiting for the my wife to get back with the car so I can go get some replacement M4-.7x16mm socket head bolts to put in after they are out I decided to give it a go with my old fashioned way to pass the time. What a success that was! I used my hacksaw and cut a slot deep into the first break off bolt. Using thumb and finger to align the blade and just kept draging it non cutting across the top until I had the smallest of purchases, then a tiny push forward and it slowly opened a the beginning of the slot. I then cut down deep. I had a kit of screw ends, typical phillips, torx and flat head for some tool but never used them. They gave me three different sizes of flats. Without the tool I just grabbed a small adjustable wrench and sized it to fit the hex shank. I then inserte the smallest into the slot as the others wouldn't fit all the way down. Pushing the bit down with my thumb and weight I very slowly turned the adjustable wrench. I felt the bolt melt smooshing ever so slightly and as I kept the pressure on and watching I saw movement. I kept moving it slowly and the pressure slowly smooshed the metal more. Once the metal was opened slightly I moved up to the next sized flat blade bit and continued. I ended up going through all three sizes and finally the bolt was out! -- happy dance! ![]() Now for the second. Repeating the hacksaw start on this one but it slipped. I repositioned and tried again. Slip. Slowed down and tried again and got a bite. When I removed the hacksaw to inspect the beginning of the slot. Dismay! -- I cut it offset from center ever so slightly. I just made my job that much harder. I cut the slot down deep and then repeated the process of smallest flat blade and going up as the metal smooshed. The bolt did not move on the smallest blade, only smooshed. Oh no! I moved up to the second blade and it started smooshing and I thought I was finished and had to wait until the tools arrive on Saturday to grind it off. But it suddenly moved a millimeter. I could tell from the force needed this wasn't going to end well. But I managed to get it to move 90 degrees before it accelerated on the smooshing and stopping on the moving the bolt. I took this time to cut a second hacksaw slot in ala Phillips style. It was worth a gamble. At the rate of smooshing and little movement I was at failure point with the first slot. I took a small lightweight hammer and tapped a regular sized flat blade screwdriver into the first slot to open up the center of the slot to allow a bigger blade. I then worked the new slot with the smallest flat blade bit and worked up. More smooshing, more work than the first bolt due to off center slot but I got it to move a little more out. The rest was lightweight hammer and regular sized flat blade to open the center on the second slot then very slow turn with pressure down and as it smooshed switch slots and tap down and repeat, as that smooshed switch slots and tap down to open up. Finally I have success! Photos to see the bolt that gave the grief. Now I am off to the hardware store for new replacement bolts. ![]() and detail of the top of the bolt after smooshings after both cuts |
