#16 | |
I checked and unfortunately they don't even carry them in stock at my location so I have to order them anyway. Quote:
My plan at this point is to just plug the hole and hopefully never have to take it out again since I usually use the side drain plug anyway. |
#18 | |
#19 | |
I may try picking one of these up if I can find it just to have on hand. Only seen a 14x1.5 S.O at local Advance Auto. I'm itching to ride again so bike being down for potentially another week is infuriating. |
#20 | |
#21 |
Update: I'd been searching locally to find the expandable plugs Bill Hilly mentioned and was able to pick one up today. Still have another to be delivered via Amazon in a couple days.
I was able to install the 1/2 plug fairly easily, filled it up with oil with no leaks, ran idle for 15 minutes and still seems fine. Going to let it sit overnight and check tomorrow. But everything seems groovy. Thanks everyone for your suggestions! Edit about 1hr in: That was quick.... So I walked out to see already and the plug had slowly slipped out, I'm thinking user error here. I fiddled with it and think I have it very snug now. With 1/2 being a little larger than 12mm makes it difficult. I don't have another quart on hand so I'll just throw in what I can and see if the plug stays or falls out again. Last edited by Slug; 11-21-2022 at 08:37 PM. |
#22 |
Popping out on it's own like that is possibly because it is either not long enough ,or wasn't installed deep enough into the case for the end to flare out . I assume you tightened the nut, and made sure the whole bolt wasn't turning. I have bought two different kinds, one had a wing nut, and one had just a small regular nut, and the end of the bolt had a slot to hold it with a flat tip screwdriver to keep it from turning with the nut. If yours does not have a slot, you may want to hold it with a set of needle nose vise grips, or something. If you don't trust it don't use it. If the plug was actually expanding, you should have actually saw scars on it from the existing threads in the hole.
#23 | ||
This is exactly what I figured I did. The wording on the instructions wasn't exactly clear so I thought it was going to thread in by itself after I got it set. The second time around I tried pushing it in as much as I possibly could before tightening the screw; so I hope it stays overnight. This is what I had to do to loosen/tighten it as I was fixing it the second time around. Quote:
The plug definitely expanded and shortened when it had loosened to where I could just pull it out. I hope I'm good this time around because I got it in well enough that I couldn't even pull it out-- and I tried quite a bit to make sure lol |
#24 | |
#25 |
Wrong thread message. I'm dumb.
#26 |
Figured I owe you all an update.
The expandable plug that Bill Hilly suggested is holding like a dream and the other one I ordered on Amazon came, slightly shorter, but same 1/2 width. There was an initial issue of me not seating it properly and it fell out, but after finagling with it to make sure it was actually in there before turning the wing-nut tight it's been holding great with no leaks. So if anyone ever runs into this issue with the bottom being stripped the expandable plug is a perfect solution. I'll also leave a direct link to the plug here: https://www.amazon.com/dp/B000CO96FE |
