04-30-2023, 03:39 PM | #1 |
2023 RX4 lost clutch?... 450 miles
First time poster....
Got my RX4 at the beginning of April and have put 450 miles on it. I am a new rider and this is my first bike; been having a lot of fun with it up to this point. I have sent in a support ticket to CSC about my issue. No response yet but it was near their closing time. Story: Made it to work just fine yesterday morning 30ish miles or so. On the way back home I noticed I had loss a bit of power going to the wheels.... Like I had to do extra effort with the engine to go the same speed as I was earlier in the morning... About half way home I completely lost power to the wheel and started coasting on the interstate.... decided to get off the interstate and pull over obviously... After I pulled over I could not shift gears; trying to go down to first... got stuck on 3rd.... Was able to eventually get it down to 1st after rocked the bike back and forth to get it to go down to 1st... Trying to find the friction zone I noticed I could no longer stall the bike letting out the clutch..... There was a small band in pulling in the clutch where I felt power going to the bike but it was essentially nothing... So frustrated I dismounted the bike and put my self in a safe condition to figure out what was happening.... Had so other bikers bros check out my bike. The believed It was the clutch cable. They adjusted on the side of the road for me but we could not get the bike to receive any power.... Ended up towing the bike back to my dad's house..... 209$... brutal... There goes my overtime I just made for that day Stuff I tried at home: At home before I adjusted anything after the tow back home the bike could not go down to first after putting it in neutral and could only go up to 3rd. So I adjusted the clutch cable at up high and low at the engine. I am able to shift threw all the gears but having to rock the bike back and forth to go up down the gears..... there is a delay of like a second or so shifting the gears after pushing the gear leaver... The bike stalls out now if I dump the clutch in first.... I was able to get the bike to go on its own power around the neighbor hood.... But it obviously feels very ruff and not even close to how it felt in that mooring going to work... I want to keep adjusting the cable but I am novice when It comes to this stuff and I am looking for advice before I adjust more stuff. Could it have been my novice driving damaging my clutch? I do not feel like I abuse my clutch at slow speeds but I could be wrong... Thoughts? |
04-30-2023, 05:58 PM | #2 |
No I don't think you had anything to do with bad clutch, even if you beat the crap out it should have lasted more than 450 miles. Just get a new clutch,then happy trails.
04-30-2023, 05:59 PM | #3 |
Oh get new clutch springs too.
04-30-2023, 06:10 PM | #4 |
My former RX4 had an issue around the same mileage or prior but it was ABS failure that affected some others at the time.. when you speak to them see if its affecting others as well.. they will send you the parts but hopefully they can guide you on how to do it over the phone as they did for me, im sure a clutch replacement is much more involved though and hopefully its just the cable, etc
04-30-2023, 09:18 PM | #5 | |
05-01-2023, 06:23 AM | #6 | |
I am thinking they got burnt up…. I do not think the clutch stuff has warranty… |
05-01-2023, 07:27 AM | #7 |
They ship the bike assembled and tested so if it was improperly adjusted at the dealer and shipped that way it should be covered, insist on it
05-01-2023, 05:42 PM | #8 |
Look at this tutorial:
https://motorepublic.com/clutch-cabl...y-adjustment-1 |
05-01-2023, 07:20 PM | #9 | |
Was not able to look at bike today.... had to work overtime... CSC responded saying to take the engine cover off and inspect the clutch plates.... |
05-02-2023, 07:25 AM | #10 |
Clutch Problem
Where in Virginia are you located? I'm in Portsmouth and might be able to help.
Peter Y. |
05-02-2023, 09:48 AM | #11 | |
Help would be dope Message times you available Last edited by Gabbiano88; 05-02-2023 at 11:07 AM. Reason: Typo |
05-04-2023, 11:22 PM | #13 |
Great, and thanks for the follow up note. Good plan, oil changes and inspect n clean plates. What color is yours?
05-05-2023, 08:41 PM | #14 | |
It can definitely be frustrating when mechanical issues arise when you are new to motorcycling and are not used to fixing things. However, in time you will get more comfortable with it and much more capable in doing it, trust me...we've all been there at one time or another. |
05-06-2023, 08:51 AM | #15 | |
Took out the oil... it was super dirty had a lot of junk attached to the oil plug and the paper filter was super nasty looking.... The oil strainers looked ok though. Did not have the 6mm hex for the clutch cover but will be getting that today. Looking at the guide for the RX3/4 clutch work.... It does not say what to torque the stuff back in? I can not find the torque values in the RX4 service manual either. Also I expect the clutch plates to be max dirty from what I saw in the oil..... I took a oil sample to send to blackstone. Forgot to take it mid stream so I scooped it out of the oil pan... |
