Old 06-21-2023, 03:49 PM   #226
Originally Posted by Dynamo View Post
Chinese Alarm system.
I bought what Herbie posted from Amazon and it was quite an easy installation, but the sensitivity is terrible even at it's most highest state. The only way it goes off as a warning is when the kickstand shocks the frame when it goes up. I can shake it and it won't go off.
Also I noticed that Herbie also had a viper alarm in another video...
I've used the same alarm on all my bikes and work perfect. You might have a bad one. Contact the seller and they will send you another one or just return it and purchase another.
Old 06-21-2023, 06:13 PM   #227
herbie   herbie is offline
I agree with what Jerry said, I’m on my third alarm from the same manufacturer and all have worked great. I did have a viper for a while but it kept blowing fuses. I believe it had an internal short to ground so I got rid of it and went back to the one in the video and have been happy with it.
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 06-26-2023, 04:33 PM   #228
Dynamo   Dynamo is offline
My exchanged motorcycle alarm works alot better.
Amazon sent me another one where I can do a comparison and it seems like its 3 times more sensitive.
Old 03-24-2024, 10:31 AM   #229
Phane   Phane is offline
After you changed exhaust, did you have to do anything to your ECU, and did your speed and power increase?
Old 03-25-2024, 07:51 AM   #230
No, I didn’t have to do anything with the ECU, it works just fine with the upgraded exhaust. The exhaust does make a noticeable difference over the stock exhaust, a little quicker acceleration and better top end.
1978 Kawasaki KL250
Old 03-25-2024, 03:27 PM   #231
thanks for the reply!
Old 05-04-2024, 11:36 AM   #232
I was having some stalling problems, but thanks to your advice I went back and checked my valve clearances and sure enough the exhaust was on point but the intake was open more than the specs! I re adjusted it and wa-la--- fixed! Thanks!
Old 05-06-2024, 10:29 AM   #233
Awesome, I’m glad you got it sorted out
1978 Kawasaki KL250
Search this Thread:
Advanced Search
Display Modes
