09-29-2023, 07:57 PM | #1 |
2023 TBR7 Petcock replacement question
Hey. The petcock on my tbr7 started leaking some gas today. Went to tighten and just poured out everywhere. Took some rough measurements. The nut connecting the tank to the petcock was a 22mm. Used an adjustable wrench to find the actual threaded portion was 16mm. When looking, do I search for a 16mm petcock? Not entirely sure, so I figured I should probably ask yall.
UPDATE: New petcock went on easily. Did mount it slightly sideways to prevent the fuel line from getting close to the top end (fuel outlet was on the left side compared to the right). For those that may want a link to an option without a reserve feature. I found it on amazon. The link is https://www.amazon.com/dp/B00XVS3FXW Last edited by Zynice; 10-01-2023 at 02:37 PM. Reason: Added the update |
09-29-2023, 08:44 PM | #2 |
Direct replacement is kind of expensive
https://www.taotaopartsdirect.com/pr...7-fuel-petcock Maybe a generic will work and save you $15 or more search TBR7 petcock. Lots of potential parts from ebay, Amazon others with a similar looking connection
09-30-2023, 06:48 AM | #4 | |
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 09-30-2023 at 09:10 AM. |
09-30-2023, 10:52 AM | #5 |
A while back, I had a little issue with my TBR7 suddenly wanting to spit, and I made the mistake of removing the little bowl on the bottom of the petcock with pliers, not knowing how thin, and soft it was. I developed a little leak from a pin hole caused by the teeth on the pliers, and ended up ordering this one from Amazon. https://www.amazon.com/gp/aw/d/B08PK...b_b_asin_title
09-30-2023, 12:30 PM | #6 | |
09-30-2023, 12:32 PM | #7 | |
