Old 01-04-2024, 06:55 PM   #7
GigaXi   GigaXi is offline
You were spot on!! Finally got around to taking off the boot and measuring it, and the link you shared is an exact fit! Engine side opening is 30mm, the bolt spacing is 61mm, and the carb side opening is 35mm. Thanks!
Originally Posted by K'hermiit View Post
There are Nibbi ones on Amazon for about 15 bucks. Probably what I will order when mine crack. If you have a good Keihin carb laying around of the right size...I would use it.
https://www.amazon.com/Motorcycle-Ma...s%2C199&sr=8-4
ID:	30606   Click image for larger version
ID:	30607   Click image for larger version
carb issues, carb upgrade, parts, templarx
Search this Thread:
Advanced Search
Display Modes
