Old 01-14-2011, 04:42 PM   #3
bigheavy150   bigheavy150 is offline
Originally Posted by mizke
youre gas needs to breath, as the motor pulls gas out of the tank it creates a suction. if you cap the intake end of the suction, eventually the motor will wont be able to pull any gas out.. try and find a vented gas cap locally and then on ebay.. it will have a small hose with a little cnc aluminum one way valve on top of the vent hose.
It does breath air in both directions, but not fuel . the steel balls are checkvalves that let air pas but not fuel.
But having 2 balls in one hole makes it just a open hole that squirts gas. I should have posted pics. I have no clue why they had 2 steel balls in there, one was about 1/2inch and the other was just bigger then a BB. I took the small one out.
Idk it just bugged me that i had a constant stream of gas running down my new frame/engine.Damn old timey cobble stone streets shake the **** out of everything. Now if i can just get the carb to stop pissing.
Search this Thread:
Advanced Search
Display Modes
