#16 |
Do like I did and just remove or gut the cat on the stock exhaust. It will be a big improvement. Nothing wrong with the stock carb unless you change the pilot jet. Those seem to be non existing. That why most upgrade the carb.
#17 |
How do I gut the cat? Same as a car? Jam a broom handle in there spin around a few times and dump out?
#18 | |
http://www.chinariders.net/showthrea...t=17913&page=3
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 10-03-2017 at 01:15 PM. Reason: added link to thread |
#19 |
That's good plan. Breaking it in with fresh American/Canadian oil, changing the fork oil, the brake fluid, and being sure that the front and back axles have grease on them, as well as the swing arm pivot bolt, is what you should do first. I would adjust the valves real soon as well (.003 intake, .004 exhaust). These bikes come from the factory almost always with the valves set too tight. You odometer reads in kilometers, so at about 800 kilometers it is broke in. That's enough for now. Then you can read up on carb tuning and exhaust effect on carburetion this winter, and change exhaust and carb before the spring riding season. I started a column on here called Hawk Talk, and if you page through it, you will find out maybe more than you want to know about carburetors and exhaust systems.....ARH
#20 |
Tinkering with a carb is why I recommend buying a mikuni. (the fake one for about 30-40 bucks on ebay) easy to get too and if you completely hose it you can just pop on your old one in an emergency.
30 is a little fat, I would start with a 25 and see how it goes from there. The higher you are in elevation the less fuel you need. less dense air means less dense fuel needed. Our colorado friends are so high...er I mean in elevation they require less fuel via the carb. This illustration helps me and I still refer to it: |
#21 | |
thanks for the confirmation
Display Modes | |
