04-16-2007, 12:33 PM | #16 |
Andi, Is that the one that's too thin?
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
04-16-2007, 12:59 PM | #17 |
Hey Folks,
for your convenience I updated the Sprocket Cross Reference making the necessary corrections based on the feedback received. I took the 428 size out of this post as it couldn't be the correct sprocket either, I will leave it at the 520 conversion for now. Everybody please make sure to compare the dimensions from your bike to the diagrams as attached form www.jtsprockets.com Note: Please remember that the chain pitch on a 428 Chain is 0.5 inches (1/2") and on a 520 chain is 0.625 inches (5/8"). That means for every tooth you will gain 1/8" in circumference, at 17 teeth the added circumference would be 2 1/8" making the front sprocket diameter too large to fit under the cover. Example: 428 Chain 17 teeth x 1/2" = 8.5" circ. 520 Chain 13 teeth x 5/8" = 8.125" circ. (should allow extra for the heavier chain). With the change in front teeth the rear sprocket will have to be adjusted as well, as indicated in some options below. Furthermore I added the various Honda Models w/year, any of these sprockets can be found on, so you may even ask your local dealer for these sprockets based on Model and the desired number of teeth (if you don't want to purchase online). JT Sprocket - http://www.jtsprockets.com/ 520 Chain Size - Complete Conversion Reference: Front only, as found on 1986-1988 Honda TRX200 SX Fourtrax; 1990-1991 Honda TRX200 Fourtrax; 1991-1997 Honda TRX200 D Fourtrax Type II. Front sprocket available in: 11, 12, 13, 14 teeth. Rear only, as found on 1977 Honda XL175/K4; 1974-1976 Honda CB200/T; 1976-1979 Honda CB200. Rear sprocket available in: 30, 31, 32, 33, 35, 36, 37, 38, 39, 40, 41, 42 teeth. Stock Ratio Set-Up: Front Sprocket P/N JTF1324.13 – Rear Sprocket P/N JTR279.35 = Ratio 35/13 = 2.6923 Highway Ratio Set-Up: Front Sprocket P/N JTF1324.13 – Rear Sprocket P/N JTR279.33 = Ratio 33/13 = 2.5384 Even More?? Highway Ratio Set-Up: Front Sprocket P/N JTF1324.13 – Rear Sprocket P/N JTR279.32 = Ratio 32/13 = 2.4615 Off Road Set-Up: Front Sprocket P/N JTF1324.13 – Rear Sprocket P/N JTR279.38 = Ratio 38/13 = 2.9231 (equivalent to a 50/17 set up that some of the Chinese Dual Purpose come with, top speed will be quite limited though). Well you get the picture. I hope this helps, enjoy. Andi P.S. If anybody would like this summary as a PDF file, eMail me at johannesmell@yahoo.com and I will eMail the attachment to you. |
04-16-2007, 01:22 PM | #18 |
liverchip,
I just put diagrams to the P/N "RD" provided, I would guess it works as he has used it successfully September last year based on his thread. The diagrams should allow for confirmation of mounting sizes for the sprockets. As per the "too thin", not sure what that means, I would have thought the thickness of the sprocket would be matched to the thickness required by the 520 chain, which I would have thought is thicker then a 428. Maybe Bruce could shed some light on that, I'm sure he is more experienced then I am. I guess he offers a kit for the proper conversion already. I will certainly give him a call when my 428 set up is worn out, I will convert over at that point. Bruce was kind enough to put together a parts order for me, bought a Battery, spark plug, exhaust gasket and most of all a few different main jet sizes to try out. I will test the different jets to see what may be the most suitable for my location and climate. On my Lifan LF200GY-5, I have the Keihin - Sheng Way 30mm carburetor and Bruce was easily able to provide the correct type of main jet in various sizes. My bike had a 98 size and he send me: 90, 95, 102, 105, 110 size jets. I will keep you all posted. Andi |
04-19-2007, 03:48 PM | #19 |
Excellent info for when I'm ready to change over.
05-30-2007, 01:53 PM | #20 |
i just read this entire thread and wanted to know something, 1st my sproket cover is off, so will a 520 chain and sprocket work on mine if so what year do i have to get the chain and sprocket off of thanks
05-30-2007, 02:05 PM | #21 |
it is a diamo ls 200 same basic concept as the other china enduros
07-08-2007, 06:36 AM | #22 |
can you still use rear 428 sprockets from jtr?
07-08-2007, 07:21 PM | #23 |
freekshow,,
Unless they went to a 428 chain in the 07 models of the DB-05, I believe you have a 520. At least my 06 DB-05 is. NET
2006 HIBIRD QH200-st atv, 2005 Kinroad 200GY-01, 2006 Roketa DB-05, 1980 Kawasaki KZ440 LTD |
07-08-2007, 08:32 PM | #24 |
net,
it is 520 learning more eveyday,thx |
10-04-2007, 08:54 PM | #25 |
does anyone know if those sprocket numbers listed above will work on the lifan sport bike?
11-17-2007, 10:01 AM | #26 |
clarification
I have read through the whole post and think i have this correct now....
-The 428 fronts lsited will not fit properly because of wobble? -Replaceing the rear is still fine? -going to a heavier 520 setup is the best option? I went to the parts compatibility section herehttp://www.chinariders.net/modules.p...showpage&pid=2 which still has the 428 parts listed. Is this an older post or are they just referring to the rear sprocket compatabilty? I really want to replace the front sprocket and not the rear or a whole new setup. Has anyone found a good 428 front sprocket since the last post? I want higher road speeds and the ability to switch it out quickly for off roading. -D |
11-17-2007, 05:03 PM | #27 |
I can tell you for sure that the JTF 259 sprockets will not work. Dimension #4 is wrong. Won't fit on the shaft because the splines are too wide.
Q |
11-17-2007, 05:10 PM | #28 |
Wanted 15 tooth
I'd like to have a 15 tooth front sprocket in the 428 size. Anyone have one they want to sell?
Q |
11-17-2007, 05:16 PM | #29 | |
Re: Wanted 15 tooth
11-17-2007, 05:21 PM | #30 |
Thanks, but really looking for a 15. Used would be OK.
Q |
Display Modes | |
