Old 05-05-2015, 08:04 PM   #3331
I called CSC this morning, and got some information regarding the shock absorber. Indeed, the shock does contain nitrogen, and the pressure of the gas might be as high as 320-375 psi. I'm sure if the nitrogen pressure were low, my shock would not be functioning as well as it is.
I am on the hunt for an aftermarket shock absorber. Is anyone else interested in upgrading the stock shock absorber?
Spud, please post the dimensions of the shock, once you remove it. I have a cool ZX-6 shock that might work well for you, and I can't use it.
Old 05-05-2015, 08:17 PM   #3332
fishman10's Avatar
headlight an shock
yep spud i got 80% of my taobo order ,,,missing the filter set which had oil and fuel filter,,which they swear they put it in the box ,,,not there ,,,but i did get the L.E.D headlight and installed it just now,,it was nt completely dark here yet ,,I do thin k its going to work well ,,as the now the bottom accent light is now a low beam,,,an the high beam is up where the regular bulb was...Great commuter bike ,, but my forks must be bottoming ,cause my fender has melt marks on it from the hot header,,,,and yes a diff rear shock could help also,,,,,,,im hoping a fork oil change helps the front,,,,also got the the new upgrade dash and centerstand installed ,,,yes ,,yes i know i gotta start new threads.............
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 05-05-2015, 09:45 PM   #3333
Originally Posted by G19Tony View Post
Very good. Please keep us informed.
If I may, what tires did you end up putting on your RX-3?
I mounted a Shinko 244 tire, size 5.10-17, on the rear wheel. I mounted a Kenda K270 tire, size 3.50-18, on the front wheel. You can see photos of the tires at the following thread.
http://www.chinariders.net/showthread.php?t=14652
Old 05-05-2015, 09:47 PM   #3334
Yes, it is a good upgrade. I liked how easy it was to drop the whole headlight to work on it.
I posted a new thread regarding changing the bulb in the headlight at the following link. If you have any further insight to add to that thread, please do so.
http://www.chinariders.net/showthread.php?t=14665
Old 05-05-2015, 10:05 PM   #3335
Originally Posted by Veteran View Post
Spud, I'm sure I'll be looking to upgrade the shock when I get back. Suspension is a pet peeve of mine. Is the schrader valve a high pressure model like on an acft or a regular car type? Can you post a picture? If it's harnessing 300+ psi, I'm thinking it's an acft type.
Good for you, Veteran. This morning I talked to Ryan and Rich at CSC regarding the possibilities for an aftermarket shock absorber.
I haven't yet removed the shock, or removed the saddle to inspect the schrader valve. However, I might make some progress in that area tomorrow. In the meanwhile, here is an image of the RX3 shock from the Taobao website.
Old 05-05-2015, 10:06 PM   #3336
Thank you, Weld. I am going to adjust the free sag and the race sag for the shock very soon. At that time I might also remove the shock, and get the measurements.
Old 05-05-2015, 10:16 PM   #3337
Originally Posted by fishman10 View Post
yep spud i got 80% of my taobo order ,,,missing the filter set which had oil and fuel filter,,which they swear they put it in the box ,,,not there...
Good for you, Fish. My order has shipped, so I hope to have the upgraded LED headlight in a few days. Whenever I am missing an item from my Taobao agent, I request a refund for it. I have never been refused a refund.
...but i did get the L.E.D headlight and installed it just now,,it was nt completely dark here yet ,,I do thin k its going to work well ,,as the now the bottom accent light is now a low beam,,,an the high beam is up where the regular bulb was...
Does the headlight have one, or two LED bulbs?
I replaced the stock fork oil with 330ml of Mobil1 Synthetic ATF. The fork action has improved significantly since I changed the fork oil. I am hoping the shock will also improve after I adjust the sag properly. However, I still want to get a quality, aftermarket shock absorber. Call Ryan at CSC and put in a request for an improved shock absorber. We eagerly await your new threads.
Old 05-05-2015, 10:26 PM   #3338
I would like to have a shock with about 5 preset, preload conditions for the spring. The Kawaskai KLR650 shock has this feature. The preload settings are easily adjusted with a wrench, and this is a very convenient feature when you are loading the bike for a trip, or unloading the bike after a trip. I think it would be great if a KLR650 shock, or a similar shock, fits the Zongshen RX3. I plan to post new threads on the forks, and the shock absorber, in the near future.
Old 05-06-2015, 02:59 AM   #3339
Miqueas   Miqueas is offline
Hi, all.
"50/50 ethylene glycol/distilled water cooling fluid with corrosion inhibitors intended for use in aluminum engines." - from de CSC blog.
Any brand from the cooling fluid?
I suspect I have a regular cooling fluid, and I would like to change iit and use a good one.
BTW I'm from Peru.
________
I just realize my visor from the master cylinder is empty. I guess it's missing break fluid, and that's why I've noticed some decrease in the breaking. Do you mine change yours?
Also if someone can check my last photos two pages ago and say something it would be nice.
The service center here is awful about this bike. I'm sure is a great bike. Let me tell you, 2 weeks ago they give the bike with less oil and less cooling fluid. Days ago recently they complete it.
Old 05-06-2015, 03:20 AM   #3340
jezzrite   jezzrite is offline
Send a message via Skype™ to jezzrite
Originally Posted by oldqwerty View Post
Unless it reappears the next time it rains, or you ride through water, or a dog pees on the bike. Yes, pee happens. I think the Chinese have the right mindset about dogs. Yum!
Gave a new meaning to raining cats and dogs.
Originally Posted by detours View Post
Maybe it's water-related, but some gear indicators require a really solid shift to activate. On my v-strom sometimes I'll be in gear but the indicator reads a dash. Happened more during break-in but less as I put on miles and started making more solid shifts.
The indicator disappeared while I was cruising on the same gear. I think it's water-related. Have to pray for another storm to test it again. BTW, thank you for the feedback.
On another case, the side panniers are definitely not waterproof. Waters leaked in from the same storm, but luckily for the left pannier, I put my stuff inside my Kriega US10 (didn't strap it at the back seat, because I was heading to an urban area with theft cases).
But for the right pannier, my tool roll was damp, and there were ponds of water inside it that dripped after I opened the pannier to check my stuff.
Tourfella perhaps? Checked TaoBao, but thinking of ordering racks only, to save up some courier fees.
People sit on an exploding, volatile, fast-moving two-wheeled killer machine, and call it "enjoying the moment".
No wonder aliens never make contact with us.
-A Zong rider-
Old 05-06-2015, 04:16 AM   #3341
Originally Posted by Miqueas View Post
Hi, all.
BTW I'm from Peru...
I think most antifreeze sold in the United States meets the criteria listed. Almost all coolant sold here is aluminum friendly, and contains corrosion inhibitors. I think this is also probably true for most, if not all, the antifreeze sold in Peru.
...I just realize my visor from the master cylinder is empty. I guess it's missing break fluid, and that's why I've noticed some decrease in the breaking. Do you mine change yours?...
I suggest you remove the cap from the master cylinder to inspect the quantity of brake fluid. If the fluid level is low, you can add some more. However, don't add too much, or you can cause the front brake to lock if the system heats enough to cause the brake fluid to expand.
If your front brake is losing stopping power, I suggest you bleed the brake fluid. Perhaps this service is covered by your warranty, and you can have the local dealer perform the service. If not, you can learn how to perform this procedure by reading the following thread.
http://www.chinariders.net/showthread.php?t=7084
...Also if someone can check my last photos two pages ago and say something it would be nice.
I don't think the 'holes' shown in your photographs are causing your problem. Have you checked to see if the coolant is full in your left radiator, as suggested?
I am sorry to hear of the poor service from your local dealer. I'm glad they finally added the proper level of oil and coolant for your motorcycle.
Old 05-06-2015, 04:20 AM   #3342
Thanks for posting the update from Malaysia. We don't get monsoon rains in the United States. I'm sure you are testing the waterproof features of all parts of your motorcycle, not just the digital dashboard and luggage. If everything else is running well, I think you are proving the water-worthiness of the Zongshen RX3.
Old 05-06-2015, 10:57 AM   #3343
katflap   katflap is offline
katflap's Avatar
Reading In the CSC Baja blog about the bloke who lost his counter shaft sprocket nut I was a little surprised.
Not by the loss of the nut, but the fact that it was a nut and not a bolt.
Though I know the CSC RX3 has a number of upgrades / differences to the Honley RX3 (UK), I thought the engines were exactly the same.
This appears to not be the case
CSC RX3
Honley RX3
Old 05-06-2015, 11:27 AM   #3344
CSC RX3
Honley RX3
I'm failing to visualize how a bolt would hold your sprocket on. Can you post of pic of your installed sprocket for us?
Old 05-06-2015, 11:51 AM   #3345
katflap's Avatar
Here you go
Search this Thread:
Advanced Search
Display Modes
