10-08-2015, 09:36 PM | #4291 | |
Thank you , now i check my model mauel, that lcd display has not have RPM section :( And manual too diagram not marked any data for tachometer , probably Cdi box unit to not have , :( But i need a simple RPM clock how i can make that easy way idk , just i think maybe same moto block type same methode measured but my mistake... |
10-09-2015, 05:45 AM | #4292 |
Ok, I understand now.
If you need to check the RPM sometimes at the workshop there are unexpensive digital multimeters suited for this. Can't figure an "easy way" for adding a permanent tachometer: the least difficult method would be to add a "tach-only" gauge; the simplest of these units senses the RPM using a wire coiled a couple of times over the spark plug cable.
______________ - ex Honda MB100 (1981) - ex Honda Nighthawk 250 (1991) - ex Honda Storm 125 (2009) - ex Corven Triax 250 Touring (2016) (Zongshen RX3 carb) Benelli TRK 502 (2018) |
10-09-2015, 07:06 AM | #4293 | |
Multimeter ? electronic measurement device or? if that multimeter mean Hertz measured if possible that solved my problem because i need RPM meter just need gas thortle marked and RPM relationship marked on gas thortle , first 3000 kilometer RPM limit run. (how i can do? ) This methode is correct? |
10-09-2015, 07:27 AM | #4294 |
Co2:
We are off-topic, so I'll send you a Private Message to avoid messing this thread. Ok?
10-09-2015, 10:46 AM | #4295 |
Volt Meter
I while back I fitted one of these voltage meters
http://www.ebay.co.uk/itm/Waterproof...item46399f6876 Cheap but quite accurate. Here's some AGM battery info i have gathered together Charge state (voltage at battery terminals) 100% 12.8v - 13.2v 75% 12.5v 50% 12v 25% 11.5v (mine is about 12.7v with the ignition on.) Voltage when starting engine should be no lower than 9.5v ( mine is 10.4v) Voltage with engine running 13.5v - 14.8v |
10-09-2015, 02:30 PM | #4296 |
As always, thanks for posting the good information, Kat. If you have time, please post a photograph showing where you mounted the voltage meter.
10-09-2015, 02:36 PM | #4297 | |
2009 TW200 (first bike ever, sold it!);2015 RX3 Cyclone in blue (first "big kid" bike ) with 13T front sprocket, 19" front wheel, center stand, heated grips, LED aux lights, CSC skid plate |
10-09-2015, 02:41 PM | #4298 |
Thanks! Reading it now...
10-09-2015, 02:48 PM | #4299 |
Hmm...
Wondering if the price is $3495.00 Canadian, and if that includes shipping as well. I'm very close (within 35 blocks) to the U.S. border, so that could be an option as well.
10-09-2015, 03:06 PM | #4300 |
It certainly was a lengthy, and probably costly, endeavor, to get the RX3 certified in Canada. I'm glad to see the bike is finally available for sale, north of the 49th parallel.
http://californiascooterco.com/blog/?p=18412
10-09-2015, 03:08 PM | #4301 |
If you want the definitive answer, place a telephone call, or send an email to CSC.
10-10-2015, 12:43 PM | #4302 | |
----------------------------------------------------------------------------------- Chasing a pesky buzz/rattle I had me speedo apart . The idiot lights (SMD style LEDs) are hidden beneath the black plastic square. Though you can't see it in the photo the black square has transparent portions in the shape of the indications shown. |
10-10-2015, 12:49 PM | #4303 |
Some bloke on one of the Chinese forums has fitted an hydraulic clutch
10-10-2015, 01:05 PM | #4304 |
Repair manual
This just arrived in Colombia, think it will be well received. Anyone have a link to English repair manual? RSD!
10-10-2015, 02:09 PM | #4305 | |
You can find links to manuals, and many informative threads by perusing the RX3 Tech Sticky, which is permanently pinned to the top of this forum. http://www.chinariders.net/showthread.php?t=14228
Display Modes | |
