New Venom x21rs rider in missouri.
Hi, just received my x21rs on Monday. Don't have plans for it other than exhaust and carb. I've ordered an AR exhaust, but I have to modify it. Has anyone tried installing a z125 exhaust on their vader, or boom bikes? It looks like the exhaust port on those is angled as well.
Greetings!
Welcome to the forum! I haven’t tried a Z125, so I can’t help you there. If you do get one, let us know how it works out.
Enjoy the Ride!
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
Welcome! You get extra points for posting a photo as a brand new member. I would check to see which footpeg fits these bikes as it could be a while before you get yours. Or perhaps Venom will grab one off another bike but they might be drop-shipping so won't have a bike to part out? They have a good reputation, but they might not get a replacement from the mfg. for a while. With Chinese bikes, you aren't looking at Honda quality or service, so be prepared, and sometimes you have to take matters into your own hands such as buying a footpeg.
#5 | |
Exhaust Question
Hey Vx21rsjohn,
How did you modify the exhaust to fit? Enjoy the Ride!
Sweet looking bike Vx21rsjohn
![]() A little off topic but can you share a picture of how you mounted your camera on your helmet? I just recently bought a similar style helmet and haven't quit figured out how I'm going to mount it. I want to mount up front like yours. I had no problems mounting on my off road style helmet.
Nice ride. welcome
I used a combination of pipe bending and an exhaust adaptor. My buddy that bent the 90 of the exhaust pipe didn't bend it back far enough. It has to go from 90 degrees to 110-115 degrees to fit correctly. So I used an exhaust adaptor to make up for the rest. Hope that helps
#10 | |
SUREWO Motorcycle Helmet Chin Mount Compatible with GoPro Hero 7/(2018)/6/5 Black,4 Session,3+,AKASO/Campark/YI Action Camera,Helmet Front and Side Swivel Mount and Adhesive Mounts with Sticky Pads https://www.amazon.com/dp/B07B7HQXS3..._r0wVBbJEQBNN4 Work pretty good. |
#11 |
#12 | |
#13 |
What brake fluid are y'all putting into your vaders? Dot 3 or dot 4?
#14 |
Cool, another x21. Here's mine. The stickers alone are worth 5 hp
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
#15 |
Nice. I haven't taken mine out yet. Just been changing stuff that I don't like and making sure everything is tight. Do you know the torque specs for the motor mount bolts? I plan on switching them out with some grade 10 when I get some miles on it. I'm going to register it next week.
Display Modes | |
