Go Back   ChinaRiders Forums > Media/Reviews/Classifieds/Sponsors > Free Classifieds > Parts & Accessories
Old 04-21-2022, 07:19 AM   #1
VaderParts   VaderParts is offline
Location: 2481 Kaladar Ave Unit 103, Ottawa, ON K1V 8B9, Canada
Top Essential Motorcycle Repair Kit Every Owner Must Have
Riding your motorcycle on a road trip is a dream of most people. Whether you use your vehicle for the daily commute or take it out for some occasions, you also need to have some handy tools in your hands. Though you can go to the repair shop anytime, there are some issues that you can handle on your own, or even sometimes you won’t find the repair shop so easily. If you want your bike to be maintained and keep running efficiently, there are some motorcycle repair tools you need to have and also know how to use them.
Today, here we are sharing some of the essential tools with you that you must go and buy after reading this article.
Chain Cleaner
The chain is one of the most crucial parts of your vehicle. If anything happens to it, your riding will be affected greatly. So, you need to be very cautious when it comes to chains, and they can get loose with the time that needs to be tightened frequently. The word is the dirt that only hinders the circulation but also affects its lubrication. This is the reason you need to have a chain cleaner that you can use to clean the chain with the help of a brush.
Chain Lube
Over time the chain loses the lubrication that needs to be taken care of; otherwise, it affects your riding and hence bike performance. Too much dry chain can cause heavy wear and tear that will damage the chain and other parts of the bike. The chain lube is used to lubricate the chain, and it is very easy to use the chain lube as you just need to pour or spray it over the chain. However, be careful while doing that as it is quite dangerous while keeping the chain running; try to rotate the tire manually to spray the lube over the chain.
Compressor repair kits
The compressor kit comes with a built-in gauge that helps you observe the increased pressure with a reading up to 50 PSI. Along with this, it also has a built-in LED light that lights up when using the alligator clips or socket. With the help of a compressor, your motorcycle tire can be fully inflated in a few minutes. Besides, you can also use it to inflate sports balls and camping equipment.
Safety Equipment
Along with the repair kits, every rider must have safety kids before starting the ride. The kit includes a pair of gloves and a helmet which are the most necessary things you must have.
Tube Flat repair kit
The dread of getting a flat tire in the midst of nowhere is something that every rider has deep down inside. This tire repair kit comes in handy while you're on the road in an emergency. In addition to a comprehensive variety of tire and tube repair materials (including a complete patch kit as well as the hand tools necessary for the task), four compact CO2 canisters are included for use in re-inflating a flat tire, which can also be used on tubeless tires if the tire has a tube. Along with that, always have the number of the spare part suppliers where you can get the parts like a Honda Grom replica 125cc, if you own such a bike.
Kit with a variety of tools
Although it would be convenient to be able to take your whole motorbike tool kit with you, it is not practicable to carry all of those items in your saddlebag at all times. It is in this situation that various tool kits come in handy. Almost everything you could possibly need for a fast fix on the side of the road is included in this pocket-sized tool kit. A number of tool kits are available, and each includes a socket driver, wrench, open-ended wrenches, as well as screwdrivers with spoken instructions.
Make sure you always have all these equipment and accessories with you so you can ride your bike anytime without worrying about anything.
At Vader Parts, We carry all parts for the Boom 125cc Motorcycles, Honda Grom Clone Parts, Baodiao BD125-10 Parts, Kawasaki Ninja Clone Motorcycle Parts BD125-11. Dongfang DF250RTS DF50SST Motorcycle Parts.
Search this Thread:
Advanced Search
Display Modes
