Old 02-27-2013, 08:43 AM   #31
katoranger's Avatar
Does the large sprocket on the axle have provisions for it to slide on the axle. Maybe you can move it to help align the motor.
Old 02-27-2013, 04:42 PM   #32
migue1760   migue1760 is offline
migue1760's Avatar
It does but only half an inch
Old 02-27-2013, 11:35 PM   #33
Most centrifugal clutches can be mounted either way; you can have the sprocket facing out or in.
Old 02-28-2013, 03:05 PM   #34
migue1760's Avatar
This clutch doesnt havw that option its just put on and screw in
Old 03-01-2013, 12:33 AM   #35
What I mean is that your clutch can be mounted onto the shaft either way. Right now, you have the clutch sprocket facing out; remove the clutch and flip it around, and the sprocket will be facing in. Does that help you?
Old 03-01-2013, 02:55 AM   #36
migue1760's Avatar
I cant do that the bore is only 1" from one side and i cant flip it to face the opposite direction
Old 03-01-2013, 10:07 AM   #37
if you could flip it around, would that help you?
Old 03-01-2013, 05:03 PM   #38
migue1760's Avatar
i cant flip the clutch it wont fit on the shaft
Old 03-02-2013, 12:18 PM   #39
I understand. What I'm asking is, if you could flip it around, would that solve your problem?
Old 03-02-2013, 01:05 PM   #40
migue1760's Avatar
Flip the clutch or the big sproket?
Old 03-03-2013, 11:52 AM   #41
The whole device. When a centrifugal clutch is mounted on a minibike, it is common to install it so the sprocket is facing the engine, and Comet makes one that will install either way.
There's a pic on this minibike forum that shows what I mean. It is using a jackshaft, but ignore that part. Notice how the clutch is installed so the sprocket is facing the engine: http://www.oldminibikes.com/forum/ge...lutch-tav.html
Old 03-03-2013, 12:36 PM   #42
migue1760's Avatar
I knew what you meant this clutch is the cheap comet clutch it has like a cap so it wont slide on the shaft or if i try i cant put the cluth so that the sprocket faces in
Old 03-03-2013, 10:17 PM   #43
Right, but you could buy a clutch that can be installed either way. Before buying one, see if that would solve your problem.
Old 03-04-2013, 03:02 AM   #44
migue1760's Avatar
Ohh. well there expensive the 1" bore, but ill keep that in mind if this one messes up
Old 03-11-2013, 02:30 AM   #45
migue1760's Avatar
I changed the big sproket more to the left but it still needs a steel plate
