05-07-2013, 09:21 PM | #1 |
LOTS of LIFAN GY-5 parts AND motor parts
Everything you see here as well as a front wheel and a COMPLETE PARTS MOTOR (167FML pushrod version) I can pick parts off of as needed. I may have other parts that are not visible in the photo, PM for condition of parts or better photos I'm letting them go cheap to those in need. :wink:
05-08-2013, 01:26 AM | #2 |
Shipping from AK or MT? I'd be interested in the pushrod motor, but shipping might be prohibitively expensive for me.
05-08-2013, 01:27 AM | #3 |
Do you have a good set of plastic side covers? Got a close-up pic of them?
05-08-2013, 01:55 AM | #4 |
The upper white one has a little crack below the rear screw hole and was damaged by a forklift when it was being unloaded from the barge Shipping is from alaska so the entire motor would probably not be possible, I think the valves and bore have been damaged from getting stored out side anyways
05-08-2013, 02:03 AM | #5 |
I think that those would require more fab work than the GY150 covers I already bought. Is the tank plastic? Got a pic?
05-08-2013, 02:18 AM | #6 |
I am planing on using the gas tank for the buggy project actually
05-08-2013, 10:06 AM | #7 |
Ok, thanks anyway. I can't think of anything else I can use.
05-09-2013, 06:05 PM | #8 |
How much would you let the motor go for?
NewStar DB 200 Facts are meaningless. You could use facts to prove anything that's even remotely true! --Homer Simpson |
05-09-2013, 10:16 PM | #9 |
The motor has a bad top end from sitting out side and shipping from alaska would be $100+
05-26-2013, 07:47 AM | #10 |
I'd be interested in the front headlight housing if its still around... I have a Roketa db 05 and the housing is cracked in two. I see it in your o.p. but barely. Any chance on a front and back photo..?
2006 HIBIRD QH200-st atv, 2005 Kinroad 200GY-01, 2006 Roketa DB-05, 1980 Kawasaki KZ440 LTD |
05-26-2013, 09:05 AM | #11 |
Is the harness i spy complete? If so how much shipped to 60473? Thanks!
05-26-2013, 11:24 AM | #12 |
I think that is a polisport mmx headlight
05-26-2013, 01:19 PM | #13 | ||
my first wiring harness failed and it took over a year of searching to find one that would work because they changed the wiring harness between years and countrys that the bikes were shipped to ( still had to change the turn signal wires on the bike to match this one). if you would like I can take pictures of all the connectors and you can compare it to yours.
05-26-2013, 01:22 PM | #14 | |
ifplugs dont match up thats not thebiggest issue forme to dealwith...LOLilike bullet connectors...easier to crimp than the stupid molex plug style....although i have acess to those too....LOL |
06-08-2013, 01:49 PM | #15 |
Hello Wild_Alaskan I was wondering if you had the throttle grip assembly for sale? I also need the choke cable, headlight plastic, and front brake booster if you have it available. Thanks man!
