More than one way to gut a cat
Well I woke up Saturday morning thinking about what I'm going to do on the hawk today. I planed on taking an early morning ride so I do the usual check list...checking oil, chain, ect. I waxed the chain and while checking the oil I noticed a good bit of rust forming on the exhaust pipe. So I might as well pull it off and repaint it. While I had it off I looked in the pipe. The welds were pretty decent and clean. I had a piece of wire and slid it in the pipe and of course hit the cat. So I figure might as well get the hack saw and cut it open to see what inside. How the hell these motors run with that plug up pipe is a miracle. Took out the drill with a 1/2" bit and started working away at it. That corrugated what ever they used was packed tight in there. After about 30 minutes of working on it I finally got it all out. I broke out the trusty old MIG Welder and welded back up then repainted it. I stuck the pipe back on and took her for a long ride. Man what a difference in power and throttle response. Who needs a $140 exhaust system when you can get the same results for free. I know Jerry's a cheap bastard.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 01-24-2020 at 09:23 AM. |
What weld? Should there be a pic? We want the pic!
I just put one of those $129 mufflers on my bike. Then we got dumped with 6" of snow so I wont know what it will do until some snow melts but it sure looks good on my bike. Congrats on gutting your cat. I cant wait to feel the new power myself. I was going to gut my cat buy Iam just learning how to use my tig and I chickened out lol.
#5 | |
Iam wondering if you cleaned up the weld inside the pipe where it meets the engine? Every weld Ive seen on that part of the pipe closed up the pipe alot.
#7 | |
Good deal. You couldn't fit a quarter through mine.
Nice Job Jerry!
Jerry, No shame in being cheap at all, I mean, look at the motorcycles we all choose to buy.
Nice work, Jerry! I'm pretty Scottish, so I don't wanna pay for a muffler either. I've modified a few, and I've also cut a cat out like you did. I figure these bikes can't outflow a well-modded muffler, so that's my preference. All that said, I did score a nice XR250R muffler for cheap on eBay, and I welded that to the midpipe of my Lifan. The only reason I did that is to satisfy the Rangers.
#13 |
very nice work!!!
i think ill do mine this week!! |
#14 |
Thanks for all the compliments. I wanted to get some ride time in yesterday. To bad the weather didn't cooperate. I went out yesterday morning and it was a warm 72 degrees. I went inside to get some breakfast and get my helmet and within an hour the temp had drop 25 degrees along with cold a_ rain and wind.
#15 |
I just epoxied one of those small rare earth magnets to the head of the drain plug. It's about a 1/4" dia. but super strong. The whole drain plug is a magnet now. I can still use a socket over it.
