Old 03-05-2017, 07:03 PM   #1
Converting rear rack to seat
I bought a pair of TaoTaos last year, A Rhino for me and a 125D for my 7 year old grandson. His little brother is almost 4 and I needed a way for the little one to come along for rides. I bought a MadDog seat off of Amazon on sale based on a recommendation from someone here (I forget who). Coleman sells a seat just like it for about half of what the MDs are going for now. The seat didn't fit well, however, as the rear rack has side and back lips that are in the way. Below are pictures of what I had to do to make it fit. Basiclly, I took off the plastic cover and then cut off all of the tubing that created the lip. I then bent some electrical conduit, making it large enough to support the seat. I then cut and welded support pieces that connected the original frame to the new one. After cleaning it up with a grinder and wire brush, I painted it textured black to match, let it cure out in the sun, and bolted it back together.
A couple notes on working with the conduit. First, safety. The conduit is plated and will give off dangerous gases when welded. The plating can be removed with muriatic (hydrochloric) acid. I always have some in my garage as it's great for removing rust. I placed the support pieces in a plastic container and slowly poured the acid in. I poured the acid back out when the reaction stopped. I brushed acid on the frame where I was going to weld with rags underneath to catch the drips.The second thing of note is that I didn't have a long enough piece of conduit to make the outside of the frame. I spliced two pieces together using 5/8" threaded rod and pop rivets. I found from another project I did that 5/8" rod will fit inside the conduit pretty tight. Once I got the ends together, I drilled some 1/8" holes through the conduit and rod, and then attached it all together using 4 rivets.
After it was all together, I rigged up a seat belt for the young one so he couldn't fall off. It worked but I want to come up with something better this year.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 03-05-2017, 07:50 PM   #2
Darth Racer's Avatar
Nice job on the new pipes and welds.. Finish product looks stock!!
Old 03-05-2017, 09:41 PM   #3
Thanks Darth. I used a HF bender and welder (cooking with gas) to get it done. I'll get up a pic with the seat on the ATV.
2016 Rhino 250
2016 Tao Tao 125D
Old 03-06-2017, 09:53 PM   #4
Below is what it looks like installed. I bought a sheet of 1/2" plywood to put on top of the rack in case the seat proves too lumpy from the bars but so far, so good.
2016 Rhino 250
2016 Tao Tao 125D
Old 03-07-2017, 10:48 AM   #5
Nice job I though about doing something similar for my Coolster 150. Thanks for sharing.
Old 03-07-2017, 11:53 AM   #6
Nice work! The welding thing has always had me buffaloed. I can stick two pieces of metal together in a very ugly fashion, but I envy this kind of stuff.
Old 03-07-2017, 05:33 PM   #7
Thumbs Up
Great job, can a motorcycle engine crash guard be fashioned out of this conduct material. Practical? Would think it would be good for its light-weight properties.
Old 03-07-2017, 06:13 PM   #8
Thanks guys. The little one is super happy he can ride with his papa. I wouldn't hesitate on using the conduit for guarding. The 3/4" stuff almost matches the tubing that most use for racks. You can get it with thicker walls also.
2016 Rhino 250
2016 Tao Tao 125D
Old 03-16-2017, 01:01 PM   #9
seat
the seat and rack looks great.... but I no one sits there as it is unsafe.( hate to sound like a doubter) but those racks are not made for much weight... and it could cause the atv to tip over... it might be good for a light kid.. or to sit back when you are resting on the trail... .. It is just a thing to think about.. good ob on it as I say
ABIBABA ATV ETC
Old 03-31-2017, 07:09 PM   #10
Thanks. He's 3 1/2 so not too worried yet. I do plan on beefing up the supports when the weather gets better.
2016 Rhino 250
2016 Tao Tao 125D
Old 03-31-2017, 09:54 PM   #11
Slaphappy   Slaphappy is offline
Man that looks good. Is there a way to strap the little guy in? Seems like a good bump might catapult him over the neighbors fence.
