I did indeed get the exhaust, and it's not in terrible condition. The front pipes and headers are in great shape, but there's a pretty good bash in on the top muffler and heat shield. The heat shield will be pretty easy to hammer back into shape, but I think the muffler may be a bit too far gone. I know that there are some mufflers out there to be had, and they're not even too expensive. First things first, though, I have to get the front tire and lower fork tubes broken down, cleaned up, and reassembled. I really need to figure out what to do with the fork rods. I think I may need to fab up a new set.
I had a little bit of time over the weekend to get the front forks and the wrecked fork rods taken apart. The damper rods will need to be replaced. There's no hope for them. I'm really struggling to find just that part, and I honestly think I'm going to have to get a whole new set of forks from e-bay.
![]() Good stuff. Like you say, make it a roller then work out sections from there without spend8ng too much on cosmetics . Then by the time little bud is 15 you should be fully restored ![]()
BlackBike, I hope to have this thing on the road and riding in 15 MONTHS, not by the time the Bambino is 15 YEARS! Those fork damper rods are really throwing me for a loop, though. On top of that, the guy who took the bike apart just tossed all the nuts and bolts that were taken off the bike into a box without any markings or organization. It looks like that box was also kicked over a few times over the years, because the more I dig into this thing, the more I fin is missing. The little bracket for the key switch? Gone. Finger release for the seat? MIA. Sprocket retainer and bolts for the front sprocket? You guessed it... I have a hard copy of the factory service manual, and that's been a big help getting organized. I'm just going to have to sit down with a box of ziplock bags and do my best to put things into at least larger subgroups, then go from there.
Not sure why I'm a sucker for punishment, but I love resurrecting stuff like this.
Emerikol, did you sign the divorce papers over this bike?
#7 | |
Almost wonder if there wouldnt be a set of forks from a newer bike that could be adapted to this. Not only for easier to service parts but to gain a disk brake.
Past bikes: '10 Gio X33 '85 Honda VF750F Interceptor '80 Honda XL185S '76 Yamaha DT250C dual sport Baja Wilderness Trail 250 '07 Honda Shadow 750 Areo Trike '01 Harley Davidson Softail Deuce Polaris Magnum 425 4x4 Quote:
#8 | ||
DarkRider, I am going to try to keep everything as original as I can. For the type of riding I'll be doing, and with modern drum brake friction material, I'm fully confident that the drums will be just fine. The biggest obstacle is going to be breaking everything down into it's component form, and then cleaning inventorying, and reassembling everything. There's already a whole bunch of things that will need attention, mostly revolving around the engine internals.
Are new rings for that engine made of unobtanium?
Weld, it's not so much that new rings are made of unobtanium, they're actually pretty easy-to-obtainium.
#11 | |
![]() --- After digging deeper in piston maker's page http://www.jhpiston.com/about_can/, found out Yamaha 7D9 (as in MZ200/ PW3028 pressure washer) is also 1.5/1.5/2.5 rings
I get that logic. It was the same with my old TW, which laid on it side. In a field. For 10 years. Ugh.
I actually got it to run and rode it for a season before tearing it all apart.
So I had a few hours to do some more tinkering on the Scrambler. The swingarm pivot bolt is the only place I've found grease that was still recognizable so far. That one came out pretty easy. I got the front triple trees off, and like everybody else who does that job I dropped the steering bearings all over my garage floor.
![]() http://www.chinariders.net/attachmen...1&d=1540812958 I'm going to need a new rear hoop. ![]()
#14 |
The worst bike I have rebuilt was in show room condiction
compared to this.. (77 Montesa 348 Cota) the KL250A1 I'm doing at the moment is bad..but nothing like this.. Just imagine the first ride around the block... thats when it's all worth it... ..
#15 |
A few more stray hours in the garage today. I managed to get the rear brakes all broken down, with an emphasis on the broken... Same thing on the rears as up front. The friction material was completely separated from the shoes, and the pivots were all seized up. I actually wound up drilling the shoes next to, and parallel the pivot pins, then hammered a flat blade screwdriver in the holes to break the shoes away from the pivots. I managed to do surprisingly little damage to the pivot pins, and I figure that the little bit the drill bit did catch the pins will just hold that much more grease when it all goes back together. The next thing to happen will be to finish stripping the frame down, then I'll start working the rusty bits with a wire wheel and some etching primer. I think I'm going to paint the frame gloss black (yeah, real original and daring, I know), along with the wheel spokes and cylinder section of the engine. I'm going to leave the wheel hubs polished aluminum, and the rims will be polished chrome. I haven't decided what color I want to paint the side covers and tank yet. I'm kind of leaning towards either a sunburst yellow, or British racing green. That's still a long way off yet. The next thing I'm going to get is a sandblasting cabinet from Harbor Freight. That will be a huge help in getting all these parts prepped and back together. But I can't get that until we get into the new house. I have a meeting with the builder on Thursday, and the timeline should lay out for us to move in around the middle of June. Fun times!
