05-05-2019, 10:13 AM | #20 |
Yup bad ass! welcome!
05-06-2019, 10:44 PM | #21 |
Do you have a link to the turbo you purchased ?. Thinking about something like that for my TBR7 not so much for the power but for altitude compensation as i'm riding between 6 and 8000ft. i think it takes about 3 psi to get to the equivalent of sea level which should be fine.
05-06-2019, 11:17 PM | #22 | |
05-07-2019, 06:38 AM | #23 |
Your the man Thanks for the info. Also i have been following your updates on your black hawk ( not your helicopter , as i think you'll post details on that later ) . Nice to see what you have done and the reasons your doing things, Please keep us updated on the chain tensioner as in how it helps or not and how it holds up. Thanks again Megadan.
05-09-2019, 04:25 AM | #24 | |
I have been doing alot of research and have decided to go blow through carb set up as most people could see by the pics. This requires the fuel bowl to b equally pressurized equal to boost pressure. Also needs your bowl vent in inlet side of carb to b blocked off or fuel will flood out of it |
05-10-2019, 09:58 AM | #26 |
I noticed the straight axle, how does it turn? Do you do sweet doughnuts with it?!
05-15-2019, 11:16 AM | #28 | |
05-16-2019, 06:42 PM | #29 | |
Might even dyno it for a laugh |
05-19-2019, 02:40 AM | #30 |
Well made a bit of progress on the weekend.
Made a reducer to go from turbo to carby Polished compressor housing Tacked up carby manifold ready for welding Got all pipe work in right place and tacked so now can go down and get it all mandrel bent Ordered black stainless braided lines and connections and mocked up where they will run And decided on placement for filter, battery, oil pump, oil cooler and accelerator cable of course cable needs shortening and a 90° bend into top of carb. |
