Old 11-04-2023, 06:16 PM   #1
BriNbigD   BriNbigD is offline
BriNbigD's Avatar
My new DLX
Hey everyone! Picked up my 2023 DLX today from TxPowerSports (as I’m local).
Did I get a counter-balanced engine?!
ID:	30330   Click image for larger version
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 EX400G Ninja 400
2023 Hawk DLX
Old 11-04-2023, 07:11 PM   #2
BriNbigD's Avatar
It’s official
MotoCheez has confirmed the c/b engine! I was going back and forth over the X and DLX because of that c/b engine. Now I’ve got everything I wanted (except for the 6th gear…maybe I should go check that too!)
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 Hawk DLX
Old 11-05-2023, 08:10 PM   #3
Do©Hawk   Do©Hawk is offline
Awesome! I have a 2022 DLX.
2022 Hawk DLX EFI
* 17T Front / 47T Rear / 428 x-ring chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Custom cutting board skid plate
* Debadged (I don't like to brag about the
superior strength!)
* Top speed, GPS verified, as equipped: 68
mph (so far)
Old 11-05-2023, 10:08 PM   #4
BriNbigD's Avatar
Is it counterbalanced?
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 Hawk DLX
Old 11-06-2023, 03:57 PM   #5
I don't think so. I think that's new for 23'. But, it's my 1st motorcycle experience so it's hard to miss what I've never had.
2022 Hawk DLX EFI
superior strength!)
mph (so far)
Old 11-06-2023, 05:16 PM   #6
BriNbigD's Avatar
When I re-read my question it sounded snarky. I apologize. I was only curious as to the 2023 updates.
Speaking of upgrades check out my headlight inside and wiring bundle behind it! All LED and smooth!
ID:	30338   Click image for larger version
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 Hawk DLX
Old 11-06-2023, 08:10 PM   #7
The snarkometer hasn't wavered up at all! Snark-free...
You've got nothing but adventures and fun ahead of you on this bike! Post a photo now and then !
Old 11-07-2023, 09:46 AM   #8
Unfortunately, text can be emotionally vague and/or misleading and is open to interpretation. I didn't think your question was snarky. All good
The LEDs are an upgrade from the 22 model. The previous owner of mine put in an LED headlight bulb. I changed out the front signals to an LED version. I'll do the back eventually, but haven't yet.
2022 Hawk DLX EFI
superior strength!)
mph (so far)
Old 11-07-2023, 10:02 AM   #9
BriNbigD's Avatar
I have H4 LED ready to install but found the picture I posted when I pulled the headlight. No boot, not H4 connection. Already LED, I’m assuming…
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 Hawk DLX
Old 11-09-2023, 05:18 PM   #10
BriNbigD's Avatar
Magnetic oil drain bolt
Unless TxPowerSports added this, I have a magnetic oil drain plug on the bike!
I upgraded the pegs with larger, better ones. Had to use the belt sander to hog off the right amount, but they are a great improvement.
ID:	30348   Click image for larger version
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 Hawk DLX
Old 11-09-2023, 05:24 PM   #11
BriNbigD's Avatar
Improvements
I’m pretty sure TPS didn’t touch the oil as what I just drained out is an abomination. I wouldn’t even call it oil. I don’t know where the Chinese get this stuff?!
I’ve also inspected all of the welds and they look REALLY good. No missed welds, etc. They’re not quite as good as on my Ninja 400, but WAY better than I could do—and more than acceptable. Even the passenger peg attachment points are welded as if someone gave a crap!
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 Hawk DLX
Old 11-09-2023, 05:36 PM   #12
From whom, I don't know, but the magnetic plug is an upgrade. On my 22 model, the previous owner made that upgrade.
I think I have the same foot pegs. I also had to grind some material off. Loctite those studs on the pegs. I lost 2 in the 1st week before I pulled them all and added loctite
2022 Hawk DLX EFI
superior strength!)
mph (so far)
Old 11-09-2023, 07:03 PM   #13
BriNbigD's Avatar
I tightened them all, but did not remove them and loctite them. Will watch closely! If I have to pull them all I will. Thanks!
DFW HMCM(SW)[Ret]
2020 FLHTK
2023 Hawk DLX
