If you don't like the messiness, Carb and Choke cleaner works excellent too. Engines like the propellant, and they speed up nicely when they get a little C&C instead of raw air.
Thinking about it further, Mr. Duck has a good point, intermittent electrical short *will* cause igniton break up on these machines. Good idea to check for grounded/melted/poopy wires, while you're in there anyways. --Vince
"Sometimes it is better to say nothing, and let people think you're an idiot, than to open your mouth and prove it." |
Check the boot on the spark plug. I changed my plug and inadvertently let the boot slide up the wire, away from the plug and it would start cutting out about mid-speed (no tach). I was grounded a few days until I discovered it!
Tim
Your mileage may vary... Shineray Allroad DB-200C |
Metcalfguitars sounds very familiar; do you belong to Harmony Central's acoustic guitar site?
No, but several of my guitars have been reviewed there.
Tim metcalfguitars.com
Well, it's good to know you because you're interested in China bikes, and the fact that you are interested in guitars, as I am, is also nice!
#6 | |
Whats the owners book call for?
John 2007 Shineray200XYI 2007 Vento Vthunder 250 |
I finally found out that a loose ignition wire was causing the stumbling at about 4,000 rpm. The wiring plug was ok, but one of the wires was loose.
As far as fuel, my owner's manual says "We recommend that the gasoline brand is RQ-90 or over RQ-90." I don't know what that means. I think that regular unleaded is 89 octane, so maybe that's what they are referring to. It stands to reason that these engines would probably run a little better on a higher octane. It might not be a bad idea to use mid price unleaded. I'm not sure; is mid price like 92 octane? |
#8 | |
Try the super i'm pretty sure thats what you should be running.
That's good to know. I've been running 87 octane (regular) in mine. I'm gonna try a higher grade.
Considering the tank size and the mileage we get, It don't hurt are wallet to much for better gas. I'm just glad my car don't call for super that would REALLY hurt.
