05-13-2009, 07:00 PM | #1 |
Craigslist score.
I just got me a new truck. 1987 Mazda for $150 and it runs and drives.
Just has alittle overheating problem. Hopefully a waterpump or something simple.
05-13-2009, 07:05 PM | #2 |
Congrats Kato... Thermostat? Ultimate in cheap overheating repairs!
I'm eyeballing a Dodge Cummins diesel to haul my ass and toys around. Certainly not $150 though!! |
05-13-2009, 07:30 PM | #3 |
My Dad is on the side of the road waiting for it to cool off. Made it the first 20 miles only about 5 to go.
It could be a thermostat or a waterpump. Hoping something simple like that. Worst case I will be finding a used engine. This is all the truck I really need. Allen
05-13-2009, 09:29 PM | #4 |
On my B2200 it was the rad, and the clutch fan.
05-13-2009, 09:31 PM | #5 |
I am thinking similar things too. My dad said it drove good and was pretty good until they hit some traffic and had to sit.
Allen
05-13-2009, 10:08 PM | #6 |
Watch the headgasket.
I had a love hate relationship with my 93. It was easily the worst driving vehicle I've ever owned (and I've owned some real junk), but it towed well, made great power, was good on gas, and reliable as hell. I tried to hate it, but it wouldn't let me I was sad to see it go, but I didn't miss it. |
05-13-2009, 10:11 PM | #7 |
That is probably the worst case. It had been replaced, but it could have failed again.
I can always part it out. Allen
05-14-2009, 01:26 AM | #8 |
Some motors use what are called stretch bolts on the heads, If they replaced the gasket and not the bolts "most people don't believe they need them" it would leak again....SOmething to look into.
05-14-2009, 01:49 AM | #9 | ||
05-14-2009, 11:19 AM | #10 | |
Re: Craigslist score.
05-14-2009, 11:57 AM | #11 | |||
But they're wrong :!: . I'm not saying this is the problem or if the truck even has them. But it something to look into due to the symptom if everything else checks out. The replacement bolts your dealer supplied are referred to as s-t-r-e-t-c-h bolts, because they are PERMANENTLY stretched when properly installed. When stretched they actually "neck down" or have a reduced diameter and area where the metal has been stretched. This reduced area has experienced Plastic Deformation, and will not hold the same torque (tension) if applied again, it will in fact stretch more, (loosing tension) and often fracture. This is why stretch bolts must ALWAYS be replaced, and never reused. Stretch bolts are used by car manufacturers for several reasons, usually none of what is reported in the hotrod magazines. First with stretch bolts automated engine assembly is much easier as the tightening of the bolt can vary by as much as 1/2 turn in most cases and provide the same clamp force. This is due to the fact that when a fastener is tighten into plastic deformation, it will not change it's effective tensile strength, (and clamp force) by very much over a given amount of elongation, (stretch). So when the pneumatic machine tightens the bolts in your engine, it can vary up to 1/2 turn and still have the same clamp force... at least in theory. The second reason car companies use stretch bolts is that the newer composite head gaskets take a thermal set in operation. Solid annealed steel gaskets may have minimal gasket compression after engine operation, but usually exhibit some, though less than any of the composite gaskets. Forget what you've read about permanent torque head gaskets, as they don't really exists. Perhaps less torque LOSS gaskets would be a better term than permanent torque. The reason for this lesson in engine design is to expose the popularity of stretch bolts. Anyone who's been in the auto industry for 20 years or more probably remembers the days when it was mandatory to re-torque head bolts on new cars after 1,000 miles or so. This was because of the above issues with gasket compression after operation. Well "stretch bolts" were intended to be the cure-all and end-all of head gasket re-torquing as the car companies were paying dealers to re-torque the head bolts on new cars, which costs lots of money. Stretch bolts may not have totally lived up to their billing. In order for a stretch bolt to be cost effective, it is often made from low grade steel with a class rating of 10.9 and a typical tensile strength of 150,000 PSI. A metric class 10.9 rated bolt has about the same tensile strength as an SAE grade 8 bolt available from your local hardware store.. The clamp force between the head and block is limited by the yield point strength of a particular bolt. The yield point is the point at which plastic deformation (stretch) occurs with little increase in clamp force. Low strength bolts limit the available clamp force which can allow head gasket leaks. By using a stretch bolt, manufacturers are attempting to maintain the same clamp force when a head gasket is initially installed and AFTER it has been thermally cycled and compressed. In reality, this doesn't always occur as the gaskets do not compress uniformly over the entire gasket surface, and there are other factors especially the structural rigidity of the head and block, that enter into the equation. Due to the many variations that can and do occur, stretch bolts have a checkered history..which is, however, improving. When used in a non-gasketed installation, stretch bolts seem to meet basic clamping requirements, as long as they are not subjected to loads that exceed the tensile strengths of their design. In gasketed applications, our experience is that they are a cost effective measure for the manufacturer and less of a hassle for the home garagiste with head bolt access issues. When (if) they fail, the symptoms are those of a head gasket failure. This typically it starts as an oil or coolant leak and can eventually lead to compression loss to the coolant system and chronic engine over-heating. This is a function of the stretch bolts having insufficient clamp force to keep the head from lifting on the gasket due to cylinder pressure. Over time the head gasket in such situation will deteriorate to the point where a leak is visible and over-heating occurs. Regardless of how competent the installer is, if the head bolts have inadequate clamp force, the problem will re-occur. The solution then is to install better quality fasteners with adequate strength to meet the demands of the application. However, these incidents are rare.
05-14-2009, 02:32 PM | #12 |
Well, I don't its the head gasket. No signs of coolant in the oil and the oil level is correct. My Dad said it was fine until he got into some traffic and then it started getting hot.
I think the fan clutch may not be working. I pulled the thermostat housing off and the thermostat was missing. The pump seems to be pumping, but is suspect. Pulled the radiator out and it looks good. Looks to be pretty new. It wasn't smoking or missing on any cylinders either. Allen
05-14-2009, 03:23 PM | #13 |
Nice find, Kato
I have a 94 B3000 that had a similar problem when purchased a few years ago. I replaced the thermostat and it's been fine since. I don't put a lot of miles on it, but I did put nearly 500 on it last Sunday. It still has less than 130k, which is pretty good for a 15 y/o truck, IMO. I hope yours is a simple fix as well. There's no better truck than the one you own, when you need a truck.
2008 American Lifan LF200 GY-5 (930 km) - Sold 2007 Kawasaki EX250 - Sold 2006 Kawasaki EX650R - My new ride! 2005 Kawasaki EX250 - A new project |
05-14-2009, 03:51 PM | #14 | |
My specialty is cylinder head work |
05-14-2009, 04:09 PM | #15 |
Wow.. that was some write up on 'stretch' bolts. We have an engineer amongst us! I always knew of them as 'torque to yield' myself.
I have 14 years in an engine shop. I've pressure tested and surfaced so many of those Mazda heads I lost count. If the problem was a cracked head, or head gasket problem, the engine would be smoking like crazy due to the antifreeze or water burning off in the cylinders, or running like shit since the compression would be seeping out of side where the gasket was split. If none of those are apparent I would expect it's a cooling system problem like you're investigating. This is of course not my specialty as I was always working on the internal components. |
