Thread Tools Display Modes
Old 01-01-2017, 12:43 PM   #136
'16 TT250   '16 TT250 is offline
What year is the TC185? I miss my TS185 that I sold a couple years ago. I hope you find an injector, since you can't run without one. I would recommend www.suzukits.com, but it seems to have shut down. :(
Couldn't it run on pre-mix?
I know with some engines you can't just eliminate the injection, but can with most.
Old 01-01-2017, 05:59 PM   #137
Landsvw   Landsvw is offline
Landsvw's Avatar
Yeah I suppose I could make a small metal plate and plug the hole left by the oil injection pump, but would prefer not to, if I can get a pump for a reasonable price.
1988 Kawasaki KLR250
1969 Honda Z50 silver tag
2002 Ford F-350 7.3 diesel
1975 Corvette
2017 Chevy Bolt
“Throttle twisting geek” -LFN
Old 01-02-2017, 03:17 PM   #138
This topic has been discussed ad nauseam on the Suzuki TS forum; some bikes (like the '70's Yamaha MX series) simply inject oil into the intake tube, between the carb and head. On those types, it's perfectly safe to block off the intake tube fitting and run premix, as long as you enlarge the main jet to compensate. The Suzuki TS uses a fancy Mikuni injector pump that splits the output between the intake stream and the left main crank bearing. Without the injector pump, the left main bearing will starve, as it is sealed outside of the crankshaft environment.
Old 01-02-2017, 03:42 PM   #139
Landsvw's Avatar
Spot on, thanks. Pump stays for sure, lol. Plus, it's just a really good system. No point in messing with it.
1975 Corvette
2017 Chevy Bolt
Old 01-02-2017, 03:48 PM   #140
Landsvw's Avatar
If it wasn't so cold I'd be out swapping cases. :(
1975 Corvette
2017 Chevy Bolt
Old 01-10-2017, 12:16 PM   #141
Landsvw's Avatar
Nothing to report. Truck running well, and it's too cold and wet to work on anything...
Happy New Year to all!
Lance
1975 Corvette
2017 Chevy Bolt
Old 01-10-2017, 08:37 PM   #142
Merlin   Merlin is offline
Lance
Happy New Year Lance
Bashan Blaze
Old 02-16-2017, 12:54 PM   #143
Landsvw's Avatar
Well dang, project is running so well, that it's boring! Although, I do have a junk yard door at the paint shop, so by mid March may have a door that isn't dented. Also, I cut the door jamb out of the one at the junk yard, so will work on that too, as the weather permits.
I got a really nice fairing for my XRL, meanwhile. I plan on putting the original XRL fairing onto the Chinese bike, and doing something about the shock on the CB too.
that's it!
Lance
1975 Corvette
2017 Chevy Bolt
Old 02-16-2017, 12:58 PM   #144
that's it!
Lance
Would be nice to see some pics of the fairing on the china bike.
Bashan Blaze
Old 02-16-2017, 01:00 PM   #145
Landsvw's Avatar
Oh yeah, also, I got the truck plates and title back, no issues, this month! very happy about that. I guess buying an auction vehicle is actually pretty easy to do, but it takes time for DMV to process the paperwork between the two states. (truck was Texas, and was abandoned/impounded in Oregon)
I'll get some fairing pictures up in the next few weeks. Still have to remove/mount to both the bikes. I really dislike that weird power rangers looking fairing on the CB.
I haven't done a thing with the TC185 except go see the PO one more time and collect a few more parts, including the oil pump assembly.
1975 Corvette
2017 Chevy Bolt
Old 03-16-2017, 06:14 PM   #146
Landsvw's Avatar
acquired a TS185 non running, worked on installing my fairing on my XRL, truck running well. Mowed yard. that's it!
1975 Corvette
2017 Chevy Bolt
Old 05-28-2017, 11:46 AM   #147
Landsvw's Avatar
Truck is running great. Coming up on first oil change. First week of June, should be able to get door painted and installed, if all goes well.
1975 Corvette
2017 Chevy Bolt
Old 06-07-2017, 12:17 AM   #148
Landsvw's Avatar
Before
1975 Corvette
2017 Chevy Bolt
Old 06-07-2017, 12:18 AM   #149
Landsvw's Avatar
During
1975 Corvette
2017 Chevy Bolt
Old 06-07-2017, 12:20 AM   #150
Landsvw's Avatar
After - should be heading to paint shop on the 21st. They have my door and we have a plan. Will post pictures!
1975 Corvette
2017 Chevy Bolt
